Old 07-31-2013, 03:45 PM
hriczko806's Avatar
hriczko806 hriczko806 is offline
Vehicle: 2004 Ram Quad Cab
Rep:91
hriczko806 will become famous soon enough
Default If regular water is bad for cooling system should I flush with garden hose?
Im flushing my coolant this weekend and have a few questions to clear up. I already bought the coolant, mopar MS-9769 coolant, and will make that a 50/50 mix with distilled water.
Basic steps:
1. drain radiator then tighten drain plug back up
2. take out thermostat and reinstall housing
3. take lower radiator hose and put into bucket
4. start car and turn on heat full blast
5. put garden hose in radiator and flush system till it comes out clear
6. Once clear shut down engine, install thermostat, tighten everything back up and fill w/ 50/50 mix
7. Start engine, keep heat on full blast and radiator cap off to bleed system and fill as needed.
8. Done
My concern is the garden hose. I was told not to use regular water in the cooling system, so shouldn't I avoid the garden hose?
My idea is to just buy a ton of distilled water and pour that in the radiator instead to flush it.
what are everyone's thoughts on this?
Old 07-31-2013, 04:31 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
If you go to Walmart, in the camper section, they sell a blue filter that screws on a garden hose. That does a darned good job filtering out contamination from hard water.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 210,000 miles To Hell and back. 14.2/96 mph NEDW
Old 07-31-2013, 04:44 PM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
And if you have a water softener to your house, that would work fine. Or the ole distilled water works good too.
Old 07-31-2013, 04:56 PM
Simple guy Simple guy is offline
Vehicle: 2003 Ram 1500
Trim Level: SLT QC 4x4
Color: Mineral grey
Rep:109
Simple guy will become famous soon enoughSimple guy will become famous soon enough
you'll be fine flushing with a garden hose. there will not be enough time for minerals to collect and corrode parts, like boiling water in a pot.. boil too long a film of mineral deposits appears... Just make sure all the garden hose water is fully drained. pouring water into the radiator with the lower hose off will only drain straight down through the end cap and onto your feet.
just don't run the engine too long because plain water doesn't have the lubricant for the pump.
having the heat on full blast does nothing besides letting you know some water has made it to the heater core. your climate control knobs DO NOT affect the flow to the heater core.
Old 07-31-2013, 06:46 PM
Hermes1's Avatar
Hermes1 Hermes1 is offline
Vehicle: 2012 Ram 1500 Sport
Color: Flame red
Rep:2554
Nailed it and good info. In the past I have used the garden hose to flush the system without any problems.
Best, Bruce
Sure you can take my truck, the keys are under my Akita.
Old 07-31-2013, 10:34 PM
Color: Mineral grey
Rep:109
I just flushed mine 2 days ago with the garden hose.
Old 08-01-2013, 12:02 PM
mb power wagon's Avatar
mb power wagon mb power wagon is offline
Vehicle: 2007 dodge power wagon
Trim Level: power wagon
Rep:68
mb power wagon will become famous soon enough
if your flushing the engine and your pulling the t-stat put the hose into where the t-stat goes into the engine. if your pulling the lower rad hose put it back on and fill the engine but leave the drain tap on the rad open there is no need to run the engine. but you can if you like. but like simpleguy said don't run it long. the water don't have the pump lubrication. after you get clear water running out of the rad drain tap pull the lower rad hose and check to see if any debris is in the water. after your satisfied the engine is flushed.
try back flushing the rad. that is where most build up happens and reduces cooling.
don't forget to back flush the heater core as well. i back flushed my rad 4 months ago and i was amazed how much came out of the heater core and how much more heat i got out of the heater core. it dramatically dropped my engine running temp as well. also like simpleguy said regular water is fine for flushing. just not for mixing with coolant. distilled water is needed for the 50/50 mix your gonna use. i prefer to run 60/40 mix but i also get colder temps in winter where i am.
Old 08-01-2013, 03:59 PM
hriczko806's Avatar
Rep:91
Thats good to know. I didnt know that coolant flows through the heater core even when the heat is off.
So if I use the garden hose Ill spray through the thermostat housing. Ill get one of those filters from wal mart too.
The small amount of tap water wont harm the engine down the road? Im assuming the hose water will remain in the block. Does anyone know how much the block holds by itself?
Also, I will definitely back flush the radiator and heater core. I have 88K miles so Im sure that theres some sediment in there.
Old 08-01-2013, 09:24 PM
Rep:68
the only way the tap water would hurt the cooling system is when it heats up. simpleguy was right when he said the minerals from tap water will cause deposits inside the cooling system. but if your just flushing the cooling system it will be fine. the block don't hold too much. not enough that it will hurt anything if there is still alittle bit in the block after your done. and yea coolant always flows through the heater core. it's just the blend doors that direct air through the heater core or a/c core or just outside air. if you have the a/c on and the truck running grab one of the heater hoses it will be hot if the engine is hot. if your worried about leaving any tap water in the block, get 2 extra gallons of distilled water and with all the hoses back on put both gallons in the rad and run the engine for a min or two. than drain the rad again and your good. but i wouldn't worry about the little bit left in the block if there is any at all. i'm thinking the engine might hold about 2 gallons. but i could be wrong.
Old 08-02-2013, 08:57 AM
hriczko806's Avatar
Rep:91
Ok sounds good. I'm hopefully going to tackle this tomorrow morning so ill use the garden hose, back flush everything, then fill with the 50/50 mix and distiller water.
Any tips for back flushing the radiator and heater core?
