Old 07-30-2013, 11:33 PM
11RamLL 11RamLL is offline
Vehicle: 2011 Dodge Ram
Trim Level: Laramie Longhorn
Color: Black/Tan
11RamLL is on a distinguished road
Default Stiffening 1500 Suspension
So I have a 2012 Ram 1500 Express Quad Cab that I pump wells with. I've got ram boxes full of tools, basically all hand tools that add an easy 200-350 lbs I'd guess. I also have an iron cross bumper on the front cause I was tired of my plastic one falling off every time it snows or the plastic rubs the ground. So anyways with the extra weight the truck rides like its a 1960 boat and even at times that it bottoms out over small bumps. My question outside of the obvious buy a 2500 is there anything I can do to stiffen the suspension up? I've put the coil spring spacers on but I don't want a lift, just stiffer ride and level stance. Thanks for any help!
Old 07-31-2013, 01:08 AM
AF Sarge AF Sarge is offline
Vehicle: 2013 Ram
Color: dark cherry red pearlcoat
AF Sarge is on a distinguished road
Check out Total Load Control. They are a sponsor of the boards here. I intend to use their airbag setup as soon as I can get the funds. I want to level out my quad cab for pulling my 16ft enclosed trailer. From my research, they seem to be the way to go.
Old 07-31-2013, 09:37 AM
racecar67's Avatar
racecar67 racecar67 is offline
Vehicle: 2014 Ram
racecar67 is on a distinguished road
I am about to do this to my 1500 for help pulling my travel trailer.
http://www.sdtrucksprings.com/index....ducts_id=18391
Mike .`.. , . .`..><((((>
Old 07-31-2013, 06:46 PM
shanerocks shanerocks is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Quad Cab
Rep:21
shanerocks is on a distinguished road
I'd do the Bilstein adjustables and AirLift 1000 in rear. Bilsteins can be set at factory height or lift if you want that in the future. Its a little stiffer ride but not too harsh at all. As for the airbags they are cheap and easy to install and can be filled enough for any use. I have both and they are great. Good luck.
Shane
( . Y . )
Old 07-31-2013, 11:02 PM
Color: Black/Tan
Thanks for the replies, my boss lives 10 hours away so technically I could charge whatever I want but being the wonderful employee I am I think I'm going to try the bilstein/air lift combo. I think it'll be the best option for my use. Now to read other forums for tuner info for my personal truck...
2011 ram 1500, suspension
