Old 07-27-2013, 11:21 AM
Squirrel19 Squirrel19 is offline
Color: Deep Cherry Red
Rep:12
Squirrel19 is on a distinguished road
Default 2013 Ram HIDs with the new projector headlights
Hey guys,
I'm very interested in converting to HID Low, High and Fog lights from stock. I've researched and found Headlight Revolution. Has any one installed this kit (GTR Lighting GEN 3 HID conversion kit (35W)). I live in canada and cannot find anyone here that does a HID conversion on the new headlights.
Old 07-27-2013, 11:55 AM
Arth's Avatar
Arth Arth is online now
Color: Mineral Gray Metallic
Rep:2028
Well you have a few options here.
If you are wanting to just put HID's in your Ram I'd recommend you check out retrosolutions for a nice kit. I'd also recommend you get the 55W 5k if you want that OEM look and great light output.
Now if you want to get the halogen projector changed out to an HID projector you need to head over to the retroshop(dot)us. There you can see about getting that projector changed out and getting HID's.
The retroshop will give you the best results for light output.
Here are some pictures.
Stock projector, stock bulbs:
Stock Projector, 5K 55W HID bulbs:
Output of stock projector 5k 55W HID's:
Now here is the same headlight with that HID projector installed.
Looks about the same right? Well..
HID Projector with 5k 55w HID's:
Notice the nice sharp cutoff vs the stock projector. The HID projectors also project the light much further than I can capture with a camera.
Hopefully this helps a bit?
Chrome... in moderation.
Old 07-27-2013, 02:14 PM
Champ1264 Champ1264 is offline
Rep:17
Champ1264 is on a distinguished road
Nice job. I just got my truck and was used to the HID's in my Commander and loved them. Were they difficult to install? Any ballasts to mount, etc.?
Old 07-27-2013, 02:19 PM
FeedMetal's Avatar
FeedMetal FeedMetal is offline
Color: Maximum Steel Metallic
Rep:83
FeedMetal will become famous soon enough
i wanna get 55w 8000K low, high and fog HIDs for my truck. i have the same headlights as the pics posted just smoked (have a sport). but not to sure where to get em or what kit?
'13 Sport Crew Cab / Hemi / 6-Speed / 3.55 / Anti-Spin - aFe Stage II CAI - MF 14" Muffler - BP 87mm TB - BP Catch Can
Old 07-27-2013, 02:30 PM
Rep:17
Yup, I'm looking for the exact same upgrade and have the same questions. I have a concern that I read somewhere with the lens' chipping with the 55w lamps because of the heat. Wondering if someone can clear this question up as well.
Old 07-27-2013, 02:36 PM
Darwin00537 Darwin00537 is offline
Vehicle: 2014 Ram 1500
Trim Level: 4x2 Limited CC SB
Rep:24
Darwin00537 is on a distinguished road
Thanks for posting this. repped!
Would be good to know cost and how hard the bulbs are to install as well.
Old 07-27-2013, 04:04 PM
FeedMetal's Avatar
Rep:83
saw something on retroshop about sending in your headlight and they can dress it or something? make some modifications. not to sure site doesnt give enough detail
others have went with a 33w 8000k and say it works great and its all PnP, not to sure what to do.
would rather have true HIDs but not at the cost of replacing lens
Old 07-27-2013, 05:07 PM
Rep:12
Thanks for the input, but has anyone installed the conversion kit from Headlight Revolution?http://www.headlightrevolution.com/2...oj-low-hid.htm
Old 07-27-2013, 06:44 PM
suckie69 suckie69 is offline
Vehicle: 2013 Dodge Ram 1500 Sport
Rep:33
suckie69 is on a distinguished road
Thumbs up HID in 2013 Ram 1500
It is quite a simple task to do with the 55 watt kit from Retro Solutions. I did my low beams as soon as I got my truck (2013 Ram 1500 Sport) and it went without any issues.
I personally highly recommend using the 55 wat kit, it is just that much brighter and seems to suite the new headlamp housings. The install is easy, it's all plug and play for the wiring. You do need to drill a small hole in the back door on the headlight assembly to allow the wires for the HID bulb to exit through. The kit includes a rubber grommet that seals the headlight from dirt and moisture again.
Once on the website and you've selected 55 watt and head lights, scroll down near the end, just enter in the bulb type and color you want (6000k is great) then you must choose dodge ram 2013+ then select regular or slim ballast's (regular arent bad to work with) and for the new Ram you do NOT need the bulb capping.
Your bulb types are as follows:
Low Beam: HIR2 (9012)
High Beam: HB3 (9005)
Fog Lamp: HB4 (9006)
**Fog lamps will require purchase of the relay harness, this information comes from Retro Solutions customer service**
I have comparison pictures of the stock halogen lights vs the HID lights if you want to see them. I still havent figured out how to insert a picture in here yet.
I have had mine installed for over 3 months now, I did a 1600km trip to Manitoba soon as I installed them and nothing over heated or showed any signs of over heating.
Bulb capping is where they basically dip the tip of the bulb in some kind of coating to help with glare and send the light back into the housing and then out in the direction it is meant to be going. The new Ram's have some kind of cover that does the same thing without needing the bulbs to have the capping done. However for the fog lights, you will need the bulb capping done.
Old 07-27-2013, 08:14 PM
FeedMetal's Avatar
Rep:83
thanks for the help. but just wondering. has anyone installed halos yet from retro solutions?
wanna do that and HIDs at the same time
