Old 07-24-2013, 05:29 PM
bighammer bighammer is offline
bighammer is on a distinguished road
Default bilsteins?
hello i have a 2008 dodge ram with a 6 inch rcx lift, i have a shock out in the drivers side front. I am gonna buy bilsteins for the two fronts? I have the shocks that came with my lift there about a 1 1/2 old. Do i need to replace all four or just the front should be fine? Also i was online looking and there seems to be a bunch to choose from. Was wondering which size bilsteins to go with? thanks for any help
Old 07-24-2013, 07:18 PM
4X4JUNKIE's Avatar
4X4JUNKIE 4X4JUNKIE is offline
Vehicle: 2007 Ram 1500 Sport Quad cab
Rep:34
4X4JUNKIE is on a distinguished road
You should be fine with just replacing the two fronts. Id check the condition of your rears before you order though. Pull the rears out, and they should be fairly hard to compress, you should have to put some body weight into it. But if the rears are fine, then you will be fine replacing just the fronts. You should definitely go with the Bilstein 5100 series height adjustable front shocks. They ride great, AND if you set them to the highest setting, you can get an extra 2" of lift out of your front end on top of your 6" lift (if your looking to go bigger)
RCX 6 inch lift, 20x9 Fuel Hostages, 35x13.5 Fuel Mud Grippers, Magnaflow exhaust, 20% tint, CAI.
Old 07-25-2013, 09:41 AM
are all the bilstein 5100 series front shocks height adjustable? It looks like i found some on some sites that say there not adjustable?
Old 07-25-2013, 09:57 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
yes there are adjustable ones for your truck. I have the same ones and used them to level mine.
contact bullysperformance here on the forum to set you up with quick shipping/best price.
Old 07-25-2013, 01:28 PM
so i can go with either the adjustable bilstein shocks or the ones that dont adjust? either ones will work with my truck?
Old 07-25-2013, 01:33 PM
Rep:1900
yup. just make sure you get the right part number
Old 07-29-2013, 03:54 PM
does anyone have the correct part # for what i need? I ordered the wrong ones. I need the ones that fit a 2008 dodge ram 1500 4wd with a 6" lift...thanks
Old 07-29-2013, 04:23 PM
ShawnC13's Avatar
Cheap Canadian Labour
Rep:1761
I would contact Andrew or Jeremiah at Bullys they will get you set up with exactly what you need and probably the lowest price you can find.
