Old 08-08-2013, 08:44 AM
tjbiker031's Avatar
Vehicle: 2002 Dodge Ram
Trim Level: SLT - Quad Cab
Color: Graphite Metalic
Rep:118
OK im going to school to become a tech and i just went through A/C. What you just described tells me that everything is fine but your radiator is bad. the tubes in the radiator are plugged up and not letting it dispate the heat from the condenser that sits infront of the radiator. Dont waste any time one anything else and just replace the radiator....i guarantee your problem will be fixed.
Old 08-14-2013, 02:38 PM
06HemiRam 06HemiRam is offline
Vehicle: 2006 Dodge Ram
Color: Tan
06HemiRam is on a distinguished road
Does the AC Condenser sit in front of the radiator on 05 Rams, on my 06 hemi its off to the side and has its own electric fan, curious if that's a redesign or something only on the hemis. Regardless, I do agree with TJBiker, the engine is cooling well at low speeds which rules out the fan as a problem, which leads me to believe its an airflow problem or coolant flow problem. The fan doesn't really pull in any extra air at highway speeds. If there were much in the way of air ducting or front spoilers I would recommend you check that first but my truck doesn't have any so to speak and I am guessing your truck is similar so I would say check out the radiator. Either give it a good flush, a close visual inspection to replace it with a new one. My 2 cents is that a thermostat, fan or other parts wont change your problem
Old 08-14-2013, 06:03 PM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
Yeah, on the '05 it is off to the side as well.
