Old 07-24-2013, 10:25 AM
J C Smith's Avatar
J C Smith J C Smith is offline
Vehicle: 2005 Dodge Ram 1500 2dr, LWB
Color: Mineral Gray Metallic
Engine: 2002-2012 226ci (3.7L) Magnum/PowerTech V6 215hp 235lb/ft
J C Smith is on a distinguished road
Default Runs hot with A/C on.
Hello all, I have an '05 1500, 3.7l engine. The temp guage usually reads right on the center mark in hot and cold weather, around town or on the highway. With the A/C on around town pointer reads 1/2 way between 1/2 and 3/4. But on the highway pointer quickly reaches top mark ( black line in what I would call normal range ) . Then it climbs toward the red, when warning on dash comes on saying check guages (duh), and stop engine. I've never let it overheat to the point of spewing coolant. Engine also stumbles when warnings come on. I've got new thermostat, bottom hose, and Mopar 5 yr coolant. Have not installed them yet pending complete diagnosis. Then I started thinking fan clutch might be going bad. Also NO coolant leaks.
Is there a way to check fan clutch? I appreciate any input .Thanks in advance.
Chris
As you slide down the bannister of Life , may the splinters point in the right direction
Old 07-24-2013, 02:43 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
That's a good question. I don't know of any technical way to check it. I usually feel it for resistance.
You might consider installing an electric fan/conversion to eliminate the clutch as a problem and reduce some drag on the engine.
Old 07-25-2013, 01:19 AM
J C Smith's Avatar
Default still runnin' hot
Warlock, thanks for the response. The clutch does have resistance and no apparent leakage. I can't believe this truck has a 1 row radiator. I do like the electric fan idea tho. Chris
Old 07-29-2013, 01:20 PM
J C Smith's Avatar
86 views and 1 response ( much thanks Warlock ). I'm bummin' here people. I'm a " certified shadetree mechanic ", but I need help with this one. Hopefully I can return the favor. Must not be enough V6 enthusiasts here. If fuel wasn't such a rip off scam, I'd love to have a V8, which probably gets better mileage than the 3.7.
Hopefully one of you pro mechanics (no disrepect here either) can help me diagnose this. Thanks everyone.
Chris
Old 07-29-2013, 03:11 PM
Simple guy Simple guy is offline
Vehicle: 2003 Ram 1500
Trim Level: SLT QC 4x4
Color: Mineral grey
Rep:109
Simple guy will become famous soon enoughSimple guy will become famous soon enough
have you tried cleaning out the fins? squirt a hose from the inside.. other than that maybe corrosion on the inside of the radiator. Might be worth it to take it to a radiator shop to be rodded if you can see any signs of corrosion from the cap.
A coolant system is fairly simple. Fan, Radiator, heater core, pump, thermostat, coolant passages, hoses, temp sensors and the cap. just check off each part of the system and rule it out. process of elimination. it's how the pros do it. Diagnostic trees.
Edit: almost forgot the most important part- The coolant.
Old 07-29-2013, 05:27 PM
deanhinsley1963's Avatar
deanhinsley1963 deanhinsley1963 is offline
Vehicle: 2004 Dodge Ram 1500
Color: silver
Rep:12
deanhinsley1963 is on a distinguished road
I would probably change the thermostat refill with straight water and see how it does. Check everything shroud,fan and blades,bottom hose for sucking together. If the thermastat fixes the problem then put your anti-freze in and your good to go. If it does'nt then I would be suspecting the water pump. I have heard of a few going out. I dont think its your fan. They will heat up idling and around town,not going down the road,unless pulling heavy with a/c on.
Old 07-29-2013, 08:19 PM
Color: Mineral grey
Rep:109
I replaced a water pump on a 04 5.7 hemi little over a year ago. Wonder if it's about the life expectancy of the pumps?
Old 07-30-2013, 12:53 AM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
Best way to check the fan clutch is to get a heat gun and heat it up to 200+ degrees. Then you can test the resistance in the fan.
Old 07-30-2013, 10:30 AM
J C Smith's Avatar
Default running hot with A/C on
Thanks fellas, I sure appreciate the input.
Simple guy, the fins are clean. I haven't looked inside yet. The coolant in expansion tank looks brand new. Speaking of coolant , the Mopar stuff isn't cheap. I've learned alot about coolant recently. It does get confusing.
deanhinsley1963,good idea with plain water. I did get a fail safe thermostat that stays open if overheating occurs.
RogerRamJet, that's a great idea with the heat gun.
I'll let y'all know the outcome. Thanks again, Chris
Old 08-08-2013, 06:14 AM
wchnu's Avatar
wchnu wchnu is offline
Vehicle: 2003 Dodge Ram
Color: red/grey
Rep:26
wchnu is on a distinguished road
Hope that works. I had to replace the radiator in another truck I have to fix this problem.
"The very atmosphere of firearms anywhere and everywhere restrains evil interference - they deserve a place of honor with all that's good.
George Washington
