Old 07-19-2013, 10:33 PM
ORT's Avatar
ORT ORT is offline
Vehicle: 2004 Dodge Ram
Rep:184
ORT has a spectacular aura aboutORT has a spectacular aura about
Originally Posted by TaderzNgravy View Post
Looking forward to stage 2. Hopefully this heat wave gets the hell out of here before we get started.
Your not kidding about the heat wave. It was brutal here today.
Sidewinder Cam/Edge Converter/Pacesetter LT's/SCT&SC Stack/Hemifever Tune/BFI #32/20% UD Pulley/Fastman TB/Triple Pillar/1 TonCooler/Sonnax/E-Cutout/Venom Hood/SRT Bumper/Roll Pan/HID's/Aeroforce Wideband/E-Fan/Hellwig/2" Drop/170 Stat/D&S Rotors/Remote Start/Hella 500's/5% Tint/Black Everything
Old 07-19-2013, 11:15 PM
TriSum's Avatar
TriSum TriSum is offline
Vehicle: 2012 Ram R/T
Trim Level: R/T
Rep:47
TriSum is on a distinguished road
Subscribing for dyno results.
2012 R/T
ARH Longtubes, Diablo Trinity, Flowmaster, Belltech 2"/4" Lowering Kit, Spohn Track Bar, Bak Flip "VP" Tonneau Cover, Oil Catch Can
Old 07-19-2013, 11:41 PM
battlerattle's Avatar
Vehicle: 2011 Power Wagon
Rep:256
I just want to say a big F*** You! I had all these plans to finally put some money away and now I have to consider doing this to my Power Wagon!!!
All joking aside, that is one awesome swap! And kudos to the guys installing, looks very clean!
Spyntec Hubs, 35" Cooper STT, Synergy Steering Brace, out of money........................
Old 07-20-2013, 01:17 AM
ericlee9386's Avatar
ericlee9386 ericlee9386 is offline
Vehicle: 2011 Dodge Ram
Rep:36
ericlee9386 is on a distinguished road
Cool ass install my friend. Does it still pull hard up top with the truck intake?
Performance mods
2800 stall, moes ported throttle body, vararam intake, ARH LT, Flowmaster 10 series, Hemifever tune.
Best 1/4 mile: 14.30 @91 mph soon to be 13's
Old 07-20-2013, 03:42 AM
hemi07's Avatar
hemi07 hemi07 is offline
Vehicle: 2010 ram
Color: blue
Rep:12
hemi07 is on a distinguished road
Looks pretty good and like how it looks stock under the hood
Old 07-20-2013, 04:49 AM
RadioFlyer's Avatar
RadioFlyer RadioFlyer is offline
Rep:146
RadioFlyer will become famous soon enoughRadioFlyer will become famous soon enough
One of my friends has a 2011 Inaugural addition and yes the throttle response is unbelievable. Looks gorgeous! I saw the oil cooler in the before installation and couldn't tell it from the pics in the after install. Can you hit us again with the oil cooler pic after you installed the engine? And where did the 6.4 intake come from, it looks like a 5.7 intake? Every one I've seen the throttle air inlet turns left toward the drivers side. That one turns up like the 5.7, is that a new one? Thanks and thanks for sharing your build. EDIT: Okay, I see that I missed the fine print about the oil cooler, too bad on that because you may need it. And the intake, can you show a pic of how it looks after you modified it, thanks? Oh and f...yeah, what are you going to do about traction (after 50 edits, lol)?
Old 07-20-2013, 05:50 AM
TaderzNgravy's Avatar
TaderzNgravy TaderzNgravy is offline
Vehicle: 2009 Dodge Ram 1500
Color: Mineral Gray
Rep:44
TaderzNgravy is on a distinguished road
He reused the truck intake to make it look as close to factory as possible. Thats why he also kept the mechanical fan.
Sh!t Talker Extraordinaire
Old 07-20-2013, 07:28 AM
ironchef2011's Avatar
ironchef2011 ironchef2011 is offline
Vehicle: 2012 R/T
Trim Level: R/T
Rep:120
ironchef2011 will become famous soon enoughironchef2011 will become famous soon enough
^Exactly. My 2012 has the two stage composite intake manifold just like the SRT, but with the TB located up. So I reused my intake manifold but used the 392 injectors and paired them with a 87mm TB from Matt at Moe's.
2012 R/T 392
Old 07-20-2013, 07:35 AM
Vehicle: 2012 R/T
Trim Level: R/T
Rep:120
Now, let's talk oil cooler. Some may have noticed that we disconnected the stock tranny cooler to run the bigger, fan assisted unit and then plugged the stocker off. When my Ram returns to L&M next week, the plan is to use the ports right above the oil filter to route AN lines up to the stock transmission cooler coupled with the stock oil temp sensor and a thermostat.
Thus far, and in 100 degree heat mind you, I'm averaging between 212-235 degrees for oil temperature. This is actually less than the Challenger guys run with their water cooled filter setup thanks to the mechanical fan and 180 thermostat. After the cooler, I hope to maintain a steady 212.
2012 R/T 392
Old 07-20-2013, 07:59 AM
RadioFlyer's Avatar
Rep:146
Good to know you have a handle on it. Can't wait to see the progress on this thing, and thanks for sharing the info!
