Old 08-01-2013, 02:08 PM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
Originally Posted by ironchef2011 View Post
Not exactly true. What they would need is a new 392 timing cover that deletes the mechanical fan and the MOPAR E-Fan. Or just the new E-Fan if you want to be more budget minded. And of course, a custom intake just like the last two SEMA 392 Rams.
The nozzle of the manifold makes a 45 degree turn to the drivers side our alternator is located right there. The alternator must be moved, the only way to move it is to install an LX style Timing Cover so the alternator is relocated to the passenger side of the motor towards the botom.
Check out the engine bay they just dropped in a 392 but you can clearly see the difference. There is no alternator on the top driver side of the motor because this motor has an LX Timing Cover and the alternator is located on the bottom passenger side of the motor.
So if you try to throw a 392 intake manifold on our truck motor the alternator will need to be moved... Thus requiring a new Timing Cover in order to move the alternator out of the way..
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 08-01-2013, 02:19 PM
mgh's Avatar
mgh mgh is offline
Trim Level: Sport RCSB
Rep:27
mgh is on a distinguished road
Originally Posted by RamTex View Post
The nozzle of the manifold makes a 45 degree turn to the drivers side that alternator is right there. The alternator must be moved, the only way to move it is to install an LX style crank case so the alternator is relocated to the passenger side of the motor towards the botom.
Check out the engine bay they just dropped in a 392 but you can clearly see the difference. There is no alternator on the top driver side of the motor because this motor has an LX crank case and the alternator is located on the bottom passenger side of the motor.
What you're calling a crank case is in fact what Mike is calling a timing cover...
Old 08-01-2013, 02:21 PM
InDeepWaterBlue's Avatar
Rep:611
Thanks for the info on the tranny, I had no idea
Old 08-01-2013, 02:30 PM
ironchef2011's Avatar
ironchef2011 ironchef2011 is offline
Vehicle: 2012 R/T
Trim Level: R/T
Rep:120
ironchef2011 will become famous soon enoughironchef2011 will become famous soon enough
If you get a chance I'd like to see some of the custom drop
components/coil-overs Mike set you up with for your drop.
It looks great in the dyno shot
How much drop did you end up with and did he C-Notch the frame like he did on his 4x4?
I currently have a Ground Force 2/3 drop on my 4x4 but would like a little lower,
also considering a Jeep GC AWD transfer case swap like Mike did too.
Sometimes I'm glad I'm so far away from L&M's shop or I'd be there for upgrades every payday.
I jumped the gun a bit on my signature as Mike will be doing the installation of the suspension next week. What we elected to do was markedly different than what's been done thus far IMO. I am a firm believer in never giving up shock travel, ever. And I won't tolerate a new setup that can't be adjusted to the exact spec I want based on corner weighting and alignment. So our parts list looks like this:
Front
  • L&M Custom 2" Front Drop Spindles
  • L&M Custom Adjustable Front A-Arms
  • RideTech Traditional Adjustable Coilovers (custom)
  • L&M/NASCAR Style Front Swaybar
Rear
  • L&M Custom Shock Perches
  • L&M Custom Adjustable Panhard Bar
  • RideTech Air Springs (just as helpers if bed is loaded)
2012 R/T 392
Old 08-01-2013, 02:34 PM
Vehicle: 2012 R/T
Trim Level: R/T
Rep:120
Exactly! You don't need an entire crank case as the accessories are located off of the timing cover, which simply bolts on to the front of the motor/block. And again, I have both for sale for someone that does not want the stealth stock look I went for so they can do the swap with ease.
2012 R/T 392
Old 08-01-2013, 02:35 PM
RamTex's Avatar
Color: Stone White
Rep:366
Yeh thats the least of your worries when trying to convert to one of those manifolds a whole myriad of things will need to be changed like he said.
I was just saying that some folks might assume that they can just slap a 392 manifold on their truck and thats just not the case...
Old 08-01-2013, 02:44 PM
RamTex's Avatar
Color: Stone White
Rep:366
Damn why the hell have i been calling the Timing cover a crank case this whole time... I need to lay off the booze...
Old 08-01-2013, 03:21 PM
Great looking truck and great numbers
The results are in and they are better than I expected. Ladies and gentlemen, she put down 404 whp and 435 wtq at HHP tonight, uncorrected. Here's a pic of my Ram on the dyno:
Old 08-01-2013, 04:04 PM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
every time i see that sema truck i throw up in my mouth a little lol
Old 08-01-2013, 04:11 PM
Vehicle: 2012 R/T
Trim Level: R/T
Rep:120
How come? Is it the stripes!
2012 R/T 392
