Old 07-17-2013, 11:03 PM
kevinj kevinj is offline
Vehicle: 2007 Dodge Ram 1500
Color: Yellow
kevinj is on a distinguished road
Default Wheels/tire...will this work?
I have a 07 Ram 1500 with a 3 inch leveling kit in the front and 2 inch blocks in the back, 20" rims. I am looking to buy some new rims and tires and was hoping to get some input or opinions. Here's what i'm thinking, stepping down to a 18x9" rim with a -12 offset and 35x12.5 tires. I don't think there would be a problem going down to the smaller rim but would like to be sure, and any input on the offset running that tire size would be appreciated.
Thanks
Old 07-18-2013, 02:27 AM
j3andit j3andit is offline
Vehicle: 2013 Dodge Ram
Trim Level: Express 4x4
Rep:18
j3andit is on a distinguished road
shouldnt have any problems
Old 07-18-2013, 12:20 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:1946
brandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant future
You'll be able to run that set up no problem!
I'm running 20x9 -12 offset wheels with 35x12.5's on a 2.5" level and don't have any issues. They did rub slightly on the back of the inner fender at first but that was easily fixed. I do have a 4th gen so the look is a little different but there's tons of pictures in my wheel/tire thread linked in my signature if you want to see how far they stick out and such.
8" BDS Long Arm Lift with Fox 2.0 Shocks | Dual Fox 2.0 Steering Stabilizer | 37x13.5 Toyo MT's | AMP Powersteps & Bedstep | Bakflip G2
EST 500 hp/1268 ft-lbs at FW | H&S MiniMaxx Custom Tuned | 4" Flo Pro Stainless TBE | Sinister EGR Delete | ARP 425 Head Studs | S&B Intake w/ Scoop
