Old 07-17-2013, 04:06 PM
Jolley's Avatar
Jolley Jolley is offline
Vehicle: 2010 Dodge Ram 1500 Laramie
Color: Tan Pearlcoat
Rep:33
Jolley is on a distinguished road
Default Adding to 2.5" level
I was wanting to get about another inch or inch and a half or so. I was just wondering how much can you lift a 2010 1500 with just a spacer kit. it has a 2.5" in the front and a 1.75 " in the back. I was thinking of putting a 1 1/2" spacer up front and a 1" in the back because it still sinks in the front just a little even with the level. Thanks
10' Laramie/35 Mud Grapps/Wheel Spacers/Level/Straights w/ 4" tips/8K HIDs/Bull Bar/22" Led Bar
Old 07-17-2013, 04:13 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
what is leveling it currently? You cant/shouldnt combine leveling kit.
What you need are the bilstein adjustable shocks and set them at 2.8" inch.
Assuming you have a 4 wheel drive and NOT the 2wd.
Old 07-17-2013, 04:22 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
What gonefishin776 said above ^^^ You can't stack leveling spacers. 2.8" on Bilsteins is the MAX you'd want to lift your front end. Any further past that and your CV shaft and A-arm angles are way too steep.
If you want it to sit more level take out that 1.75" rear spacer and get some 1" spacers from Top Gun Customz.
