Old 07-16-2013, 05:27 PM
Kooker Kooker is offline
Vehicle: 2012 Ram Express Regular Cab
Kooker is on a distinguished road
Default What silicon do you use when baking headlights?
What silicon or adhesive do you use after baking, painting, then reassembling the headlights? I have a Home Depot right next to my house so ideally I'd like to get it from there.
De-Badge, Blacked-out Grill and Tailgate Badges, Blacked-out Headlights and Taillights, Sublime Green G2 Caliper's, Retro-Solution 35w 8,000k HIDs, LED: (Tag Lights, Reverse Lights, Interior Lights), Ground Force 2" Rear Drop, 22" KMC Slide
Old 07-16-2013, 06:07 PM
Asur Asur is offline
Vehicle: .
Rep:4371
what keeps the lens attached to the rear housing is called "Butyl Rubber Glue"
its a synthetic rubber, elastomer. Butyl rubber glue is impermeable to air and used in many applications requiring an airtight rubber seal like head light housings, it is the best product to reseal you headlamps. you can find this at theretrofitsource, not sure you can find this at Homedepot.
Old 07-22-2013, 04:15 PM
jramlvr jramlvr is offline
Vehicle: 4th Gen Ram
jramlvr is on a distinguished road
napa carries butyl, also called "window weld", etc. Never found the right stuff at Home Depot.
Auto paint stores may carry it too, my local one does.
2010 Ram 1500 Crew
Old 07-22-2013, 09:44 PM
birdboy birdboy is offline
Vehicle: 2010 ram 3500
birdboy is on a distinguished road
so you guys put in oven to disassemble, at what temp and how long? thanks
Old 07-22-2013, 10:20 PM
CdnoilRAM CdnoilRAM is online now
I push the skinny pedal
Rep:3277
I use the black exterior silicone. 3 sets of lights and only one leak, but that one was not a seal issue. I even use the stuff to adhere my halos rather than using epoxy.
Kurtis
