Old 07-16-2013, 12:42 PM
RamRod55's Avatar
RamRod55 RamRod55 is offline
Vehicle: 2010 Ram 1500 4x4 Crew
Trim Level: Big horn
Rep:26
RamRod55 is on a distinguished road
Default Muffler question
I am about to order the flowmaster 40 muffler(only) and do it via DIY, I thought I remember reading something a few weeks back that this 40 muffler can basically get swapped right in place of the old stock muffler and run back out to the factory dual exhaust? If it cant what else do I need to run this to the factory duals??
Old 07-16-2013, 01:06 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
Yup, a simple muffler swap like that is easy to do. You will put the muffler all the way back to the factory dual pipes and you will need about 2ft (high estimate) of 3" pipe to fill in the gap on the front. I also definitely recommend welding the new muffler in rather than just using clamps. That way you avoid any leaks which sound terrible.
Old 07-16-2013, 01:18 PM
RamRod55, if you need pricing on this flowmaster, let us know.
Send us an email at sales@bullysperformance.com
We can extend the forum discount to you
Old 07-16-2013, 02:43 PM
RamRod55's Avatar
Rep:26
this is just gonna be any 3" stainless steel pipe correct? And do clamps come with it or something??? I deff am going to weld it in. Thank you btw!
Old 07-16-2013, 02:46 PM
Rep:2026
Yup, stainless is definitely a good option as it will match the rest of the stock piping and obviously not rust out. Just buy 2 ft of it (or more if you want to be super conservative) and you should be good to go.
Clamps probably don't come with it since you're just buying the muffler. I have a full Flowmaster cat back that came with clamps but those are sitting on the shelf since I chose to weld mine in as well.
Another heads up, disconnect your battery when welding on your truck. Otherwise there's a chance of frying your ECM.
Old 07-16-2013, 10:32 PM
RamRod55's Avatar
Rep:26
Awesome thanks for the help!
diy exhaust, flowmaster 40, flowmaster muffler, muffler
