Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - General Discussion > Dodge Ram Special Edition Models > Dodge Power Wagon
Old 07-13-2013, 03:16 PM
mb power wagon's Avatar
mb power wagon mb power wagon is offline
Vehicle: 2007 dodge power wagon
Trim Level: power wagon
Rep:68
mb power wagon will become famous soon enough
Angry damn cel on again!!!
ok my cel is on again. it gave me 2 codes 0467 and 0467p. i also get 0465 and 0465p now and than. i have replaced the gascap but my odometer still says gascap. i am thinking maybe my vent nozzle isn't sealed? could that cause this?
Old 07-14-2013, 10:19 PM
battlerattle's Avatar
Vehicle: 2011 Power Wagon
Rep:256
Another cause could be your evap can. Generally it has its own code but can throw a gascap code as well.
Spyntec Hubs, 35" Cooper STT, Synergy Steering Brace, out of money........................
Old 07-14-2013, 11:16 PM
Rep:68
thanks battle gonna check that tomorrow
Old 07-25-2013, 10:56 PM
Rep:68
how can i check the evap can? and where is it at?
Old 07-26-2013, 03:23 PM
Rep:256
Plastic bok underneat near fuel tank with 2-3 hoses going into one side. Make sure all the hoses are connected tightly and the little vent portion isnt plugged.
Old 07-27-2013, 09:37 AM
Rep:68
thanks battle. gonna look into it. im gettin tired of havin to clear the codes if the truck sits for more than 2 days. it's weird the cel light only comes on if i let it sit for 2 days. if i run it everyday the light don't come on.
Old 09-18-2013, 12:27 AM
Rep:68
well it looks like i need a new evap can. anyone have any idea what one of those go for?
Old 09-18-2013, 07:21 PM
Rep:256
Well they are not cheap. You should be able to use one off any gas 2500 truck though (think pick-a-part) and be good.
Can I ask how you know its bad? If its an obvious crack or something that sucks, but there are a few tricks that can be used to bring some life to an old one.
Old 09-20-2013, 02:12 AM
Rep:68
yea it has one small crack on the side but i think i might be able to use a square piece of heavy plastic with some silicone and then to make sure it stays on real good i'll use a hot glue gun or a soldering iron and a few zip ties to plastic weld it. how do you breathe new life into one of those evap cans? i'm willing to try what i can to make sure it's good so i only take it out once.
Old 09-20-2013, 12:04 PM
Rep:256
The evap can is just that an evaporator. When things evaporate lots of residue gets left behind. Right now the crack is your biggest worry, first you have to get that fixed. If you can do that successfully and the inner chambers remain intact I have actually has luck using mild soap and water solution to flush the canister. Once flushed you have to let it bake in the hot sun for a few days to completely dry out.
