Old 07-13-2013, 10:26 PM
h2oman's Avatar
h2oman h2oman is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Express 4X4
Rep:308
If you go with an E rated tire irregardless of the size you will be fine with the tires. Of course you need to know your weights. I assume you already know your traIler, The idea that you can't tow a trailer because you have a lift is just silly. In California we have more people towing with lifts than most states have people. Go for it op.
333Half the beast
I used to be
Old 07-14-2013, 01:00 PM
Trim Level: sport
Color: green
Rep:643
the height of the lift does come into play as it raises the center of gravity. a "normal lift" with the right tires should be fine.
Old 11-28-2013, 02:11 AM
Disturbed69 Disturbed69 is offline
Vehicle: 2012 Ram 1500
Trim Level: Outdoorsman
Rep:53
Disturbed69 will become famous soon enough
Default lift
I have the leveling kit on mine with 295/70/18 Nitto terra grapplers. I've also installed the TLC kit after my first trip. I tow a 36' camper and have no problems. I've seen that they say don't use a WD with bags but also ready that is you remove your springs and just use the bags. Keep in mind this is just from my research. No one shoot me as I will say now I'm not an expert or pro just speeking from my set up and experience.
