Old 07-13-2013, 12:53 AM
jello03825 jello03825 is offline
Vehicle: 2014 Ram 3500
Trim Level: tradesman
Color: silver
jello03825 is on a distinguished road
Default Towing with the mopar lift
Has anyone installed the Mopar lift P5155797 and a travel trailer? I been wanting to level my truck off and increase the tire size a little but not sacrifice the tow quality. I have a 2012 ram quad and tow a 27 ft travel trailer.
Old 07-13-2013, 10:58 AM
h2oman's Avatar
h2oman h2oman is offline
Vehicle: 2012 Ram 1500
Trim Level: Express 4X4
Rep:349
Neither lifting nor leveling should reduce your tow capacity. You will have to readjust your ball height and maybe your weight distribution hitch. But, other than that, lot's of people do it without issue. Go for it.
333Half the beast
I used to be
Old 07-13-2013, 01:09 PM
BoosTT BoosTT is offline
Vehicle: 2011 Ram 1500 Quad Sport 4x4
Color: Gray
Rep:15
BoosTT is on a distinguished road
This is bad advise. Go over to rv.net to discuss this with people who own tts. The big tires have more sidewall that flexes and can cause handling problems.
Old 07-13-2013, 01:34 PM
Trim Level: sport
Color: green
Rep:657
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
never bad advice to get more opinions. you can't just lift and add bigger tires without doing some research. you can of course do all this and still toe, just need to know how big of a tire you can add paying attention to side wall strength and flex. do you need an e rated tire or less. just need to make informed choices.
Old 07-13-2013, 02:08 PM
h2oman's Avatar
Rep:349
Ok. My bad. I guess everyone with lifts and levels should stop towing immediately. I'll stop advising. I apologize.
333Half the beast
I used to be
Old 07-13-2013, 03:55 PM
naturecannon's Avatar
naturecannon naturecannon is offline
Vehicle: 2012 Ram 1500 Quad
Trim Level: Bighorn
Rep:286
naturecannon is a jewel in the roughnaturecannon is a jewel in the roughnaturecannon is a jewel in the rough
I leveled with blistein 5100's and bumped up to 34" tires. No issues or tow quality sacrifices.
These are great tires all around and for towing too, small bump in size from stock and no issues with a level:
Toyo Open Country A/T II 275/65R20 : 34X11, Load Range E (10-Ply)
65K warranty
Bilsteins 5100, Magnaflow 18, Lines X liner, Airlift 1000, Toyo Open Country A/T II, Cabin Filter, Bully Dog, Billet Catch Can, 3.92, Low Profile ToolBox, Front Cab Window Tint
Old 07-13-2013, 06:34 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
A lift has nothing to do with tires... Sure you can assume the OP is going to put bigger tires on, but that wasn't the question. Plus you can get bigger tires that still have high load ratings. TONS of guys are doing that. So I'm gonna say you're the one giving bad advice for not doing your homework on available products....
OP, as others have stated you won't have any issues as long as you have the right setup. You will need a bigger drop on your receiver for sure. Adjusting your WD is essential but also a given. Adding some airbags like the Airlift 1000's or TLC bags will definitely help you as well.
Old 07-13-2013, 08:19 PM
Color: Gray
Rep:15
You need to research if the lift kit would reduce your payload. An 27' TT and family would already be close to your max payload.
Old 07-13-2013, 08:23 PM
Rep:2026
I lift kit shouldn't reduce your payload in any way. I don't see why it would. And you don't know any specs on the travel trailer regarding weight so how can you even comment on the tongue weight being close to max payload. I bet it's half the max payload or lower.
Old 07-13-2013, 09:16 PM
Color: silver
Thanks everyone, this is kinda what I have been running into whenever I search, people on both sides of the fence. My plan is of to go to big of a tire, either a 35 12.5 or to get a 65 sidewall. Considering I have a 60 sidewall stock that does not seem to be that big of a jump in tire height. I was planning on 5100 in the front and airbags in the back but the rv sites don't reccomend air bags with WD hitch. So I thought bigger springs in the back would be better. More input from people would be good
