Old 07-12-2013, 02:43 AM
BCboy's Avatar
BCboy BCboy is offline
Vehicle: 2003 Dodge Ram 1500 4.7
Color: Blue
BCboy is on a distinguished road
Default 03 4.7 need buying advice on lash adjusters
I bought a 2003 quad cab today with the 4.7 powertech in it and on the way home it managed to spit out something in the valvetrain and leave a dent in the valve cover. The engine bogged and then stalled. I had a quick look at the engine bay and there is a dent/crack towards the back of the engine on the passenger side valve cover. The crack is about 1/4 inch long total. From the little research that I have done it looks like the rocker arm (correct term?) decided to fall out from between the lash adjuster and the camshaft due to a sticky valve. I am thinking that if the piston decided to say hi to the valve that there would be a much bigger hole in the valve cover and possibly the hood.
Current plans are to start with pulling the valve covers to see what's going on around the cams and replacing the lash adjusters. I will pull the heads if necessary to have a look at the piston. Which brings me to my next question. Can anybody recommend one brand over another for lash adjusters? Do i stick with genuine mopar lash adjusters from the stealership or are they a pretty generic part that I am ok with ordering from the local parts store and not caring about brand? Is there a specific online store that you guys recommend?
2003 blue Q/C 4.7 powertech Automatic 4x4 SLT
Old 07-14-2013, 02:45 PM
icywhite's Avatar
icywhite icywhite is offline
Vehicle: 04 dodge ram
Rep:29
icywhite is on a distinguished road
Airram.com and yes just go with the basic no other opt other then solids
2/4 drop,h.o. cams,4.56s posi, stage 2 cai, 70mm tb, 180t, cutouts, efan, centerforce dual friction clutch,short throw shifter 24%, sct(tuned by flying ryan), high flo-Y, 3 inch exaust , jbl headers, 2013 intake manifold, nitrous, killian ported heads,leds and hids on all lights,
Old 07-15-2013, 01:50 AM
BCboy's Avatar
Color: Blue
Thanks for the reply. Ill be placing an order shortly.
Old 07-21-2013, 01:56 PM
BCboy's Avatar
Color: Blue
So I ordered the solid lash adjusters and the miller tool from airram. Now just waiting for them to arrive.
In the meantime I replaced the spark plugs and and the throttle position sensor
I had a code P0068 and I figured that the plugs were due for a change.
When I pulled the rear passenger plug it came out a little harder than the rest of them. Just a little bit of dragging as it came out of the threads. Turns out the hook on the bottom is mangled and a few threads aren't perfect anymore. This is the cylinder that I had the rocker arm fall out of.
So now im looking at either pulling the motor and replacing it or pulling the motor and fixing the parts in the cylinder head. I need to have a look at both the valves and the top of the piston before I do too much though.
Last thing, the timing chains and sprockets. Are they probably needing to be replaced at 300,000 kilometers? Or are there specs somewhere that say the amount of deflection and tooth wear is acceptable?
If anyone with experience wouldn't mind chiming in that would be great.
Old 02-24-2015, 03:15 PM
Gniccum Gniccum is online now
Vehicle: 2007 Dodge Ram 1500 4.7L V8
Color: Pearl Blue
Gniccum is on a distinguished road
Solid lash adjusters are $355. The tool is $125. Did you really spend that much money to replace the lash adjusters? It's something I'd like to do but won't unless it's necessary.
Old 02-25-2015, 12:28 PM
Maddevill Maddevill is offline
Vehicle: 2003 Dodge Ram 1500 Quad
Color: Grey
Rep:27
Maddevill is on a distinguished road
At that mileage I would replace the cam chains, sprockets and tensioners. If you find the engine is bad, you can get a refurbished long block with updated parts for around $2500-3500.
4.7, lash adjuster, no start
