Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 8.0 Liter V10
Custom Dodge Ram Performance Mods - Engine - 8.0 Liter V10 Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Old 07-11-2013, 06:34 AM
Valvebounce Valvebounce is offline
Vehicle: 1973 Valiant charger
Valvebounce is on a distinguished road
Default V10 Conrod questions
Bit of a newbie question for the experts.
Are the Conrods from the Truck V10 engines, the same as the rods found in the Viper V10 engines?
I'm asking as I read somewhere that the Ramm engines are somewhat different to the Viper ones. (different block material?)
Old 09-02-2013, 02:15 PM
69beeguy 69beeguy is offline
69beeguy is on a distinguished road
Send a message via Yahoo to 69beeguy
Default everything
hey,
i have been looking into this for a project i would like to start. between viper and ram V-10's virtually everything is different. however, if you are looking into V-10 mods, think 5.9 magnum plus 2 cylinders. the 8.0 has a larger stroke than the 5.9 and the bottom end is a little different too. but rods and pistons are the same. i have been looking into 4.0 jeep con rods. they are 100g lighter, but much stronger. and there is a ton of them out there. they also have smaller rod journals, but same width. this way, you can offset grind the crank and get close to 500 cubes depending on overbore. the 8.0 has a 8.4:1 compression ratio. i do not physically have one yet to tear apart, but this should bring you close to zero deck. i am looking at picking one up here soon. i will have to beef up my engine stand because the 8.0 is 800lbs+.
jim
