Old 07-11-2013, 07:03 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
You need to be at least leveled to fit 35's. I don't see any struts or coil springs, so does your truck have torsion bar suspension? If so you can just tighten them up to lift the front. The easiest way to tell if that's already been done is to measure the fender heights front and back. If they are fairly similar then your truck has been leveled. If there's a 2"-3" difference then it has not.
Are you not planning to run a 4" suspension kit though as stated in your original post?
Old 07-11-2013, 07:35 PM
Rhino65 Rhino65 is offline
Vehicle: 2007 Dodge ram
Rhino65 is on a distinguished road
Initially I was and still am I suppose look'in to put a 4" kit on it
Old 07-11-2013, 08:16 PM
Ok..so now I'm think'in maybe just a leveling kit...the rear is at 9" from tire to wheel well top and the front is 8"....I looked at the Rough Country kit and the problem I see is I don't have coil springs...
Old 07-11-2013, 08:19 PM
Rep:2026
I'm assuming you have torsion bars then and they've probably already been cranked up to level the truck. You should be able to fit the 35's on there then.
Old 07-12-2013, 08:45 PM
With the torsion bars cranked, does that give it a crap ride as far as bounce'in or is that a shock problem?
Old 07-13-2013, 02:49 AM
Rep:2026
It will definitely make your ride a bit stiffer. But if it's bouncing like crazy it's warn out shocks
