Old 07-10-2013, 02:47 PM
Rhino65 Rhino65 is offline
Vehicle: 2007 Dodge ram
Rhino65 is on a distinguished road
Default Few Questions...4x4 shops and Rims
I picked up a 2007 Ram 1500 and I'm look'in to put a 4" Rough Country lift on it.Anyone have any idea what an estimate for labor would run to have it installed around South Plainfield, New Jersey?Also would appreciate names/websites of any 4x4 shops in the area. The current tires are P27565R18's...what's the biggest tire I can get on the current rims?Thx for any and all responses
Old 07-10-2013, 03:25 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
My guess is around 6-7 hour install time for the lift so at $80 an hour you're look at around $480-$560. Not sure of any shops in the area as I'm from the west coast. Hopefully someone will chime in for you on that.
As far as tires go with the 4" lift you'll clear 35x12.5's no problem but I believe you'll need 1/4" spacers if you're using the stock rims.
Old 07-10-2013, 04:17 PM
I don't believe the rims are stock although I don't know for sure, are you saying that 35's will fit stock rims?
Old 07-10-2013, 04:19 PM
Rep:2026
You could post a picture of the rims. We'll let you know pretty quick.
Yes, you can fit 35x12.5's on stock rims no problem. You just need 1/4" spacers to avoid rubbing on the UCA.
Old 07-10-2013, 04:36 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
yeah RCX says 5-6 hours install time. But with an older truck you could probably tack on another hour. So 7 hours at the shop rate of usually $80-90/hr then another 70-90 for an alignment.
Old 07-10-2013, 05:39 PM
Can't figure out how to post a pic
Old 07-10-2013, 05:42 PM
Rep:2026
Here's a few threads explaining how to do it.
Using photobucket (best way IMO): http://www.ramforumz.com/showthread.php?t=139666
Using Ramforumz: http://www.ramforumz.com/showthread.php?t=38375
Old 07-10-2013, 06:01 PM
Old 07-10-2013, 06:02 PM
Figured it out...
Old 07-10-2013, 06:06 PM
Rep:2026
If you post the IMG code rather than the link it will post the picture directly onto the thread.
Do you have a picture looking back from the front of the truck showing the lower control arm and the CV shaft?
EDIT: A picture like THIS is what I'm talking about.
