Old 09-09-2013, 01:45 PM
Billacuda's Avatar
Billacuda Billacuda is offline
Trim Level: ST/Express
Color: Mineral Gray
Rep:113
Billacuda will become famous soon enoughBillacuda will become famous soon enough
My oil runs at about 235-240 regardless if I'm driving it or it's idling. I figured this is the optimal temperature since it never fluctuates even when towing. Should it be that much lower (180)?
2013 Ram 1500
2013 Ford Focus
Old 09-09-2013, 03:25 PM
Outdoorsman2012 Outdoorsman2012 is offline
Vehicle: 2012 Ram Outdoorsman
Trim Level: Oudoorsman
Rep:39
Outdoorsman2012 is on a distinguished road
From what I've read that's the way the 13s are. I've done a lot of reading on this and it looks like the highest conventional oil should be run at is 240 and 260 for synthetic. My vehicle was running about 200 not towing and at least 220 when towing. What are you towing? If its a smaller lawn trailer weighing 2000lbs you'll probably see no change I'm towing a 11 foot by 8foot by 30 foot brick down the road so lots of wind reistance along with weight. This was more ease of mind thing as all trucks should have warning lights but I just wanted it for peace of mind and some help on those hot days
Old 09-10-2013, 11:20 AM
racecar67's Avatar
racecar67 racecar67 is offline
Vehicle: 2014 Ram
racecar67 is on a distinguished road
Yep mine was normal at 200 before the cooler and spiked to 258 going up a 6% grade. thats when I decided on the cooler. Once I get some pictures of the install I'll post.
Mike .`.. , . .`..><((((>
Old 09-10-2013, 11:56 AM
dodge man's Avatar
Vehicle: 2004 Quad Cab diesel
Rep:221
Do they have a cooler from the factory? It seems like some trucks can with a cooler from the factory, some times it runs the oil through the radiator, which at times wouldn't cool it very much.
Old 09-10-2013, 07:28 PM
Billacuda's Avatar
Color: Mineral Gray
Rep:113
I'm towing a 5500lb travel trailer. Lots of mountains here so almost always going up hills until we are on our way home.
2013 Ram 1500
2013 Ford Focus
Old 09-10-2013, 08:40 PM
Rep:39
My truck is pretty much the most factory equipped truck from ram. My half ton came with e range tires along with class 4 hitch and the 3.92 rear all standard. This does not mention anything about oil cooler only heavy duty cooling and transmission cooler. I wonder what is different in the 2500 to make the cooling better for the oil?
Old 09-10-2013, 08:55 PM
spoiler's Avatar
spoiler spoiler is offline
Rep:364
I never tow anything...EVER. and I watched that "how too" with rapt attention. Really nice work. Excellent clear and easy to understand.
Old 09-13-2013, 03:04 PM
dodge man's Avatar
Rep:221
Some trucks and some cars come with an external oil cooler and/or and oil cooler that uses the radiator. I have a 3/4 ton truck and I can't even tell you what it has. For sure most of them come with an external tranny cooler plus the one in the radiator. I'm also think my wifes 300C and my Challenger has a power steering cooler, which isn't much more than routing the line in front of the car to cool it down a bit.
Old 08-27-2014, 10:15 PM
BurninVernon's Avatar
BurninVernon BurninVernon is offline
Vehicle: 2014 Dodge Ram 1500
Color: Deep Cherry Red
BurninVernon is on a distinguished road
Bump.
Very informative thread. I also tow a travel trailer at about 7K lbs and my oil temps go way up. Granted it's been 100 degrees out lately, but man most of my upcoming trips involve going up Cajon pass and then through the Mohave Desert. No way I'm going to make it without extra cooling, even with Synthetic oil.
I'm not sure my truck includes an extra oil cooler from the factory. Need to find out.
If any of the original posters have more info to share I'm listening with ears open!
Jason
Old 08-29-2014, 09:09 PM
2012Outdoorsman 2012Outdoorsman is offline
Vehicle: 2012 ram
Trim Level: Outdoorsman
2012Outdoorsman is on a distinguished road
I'm the op, I had to slightly change my name as I forgot my password.
I since posting I have done a decent amount of camping this year putting on about 4000 miles of towing. I did have one leak on one of the fittings that required tightening of a hose clamp it has sense held which was during the winter. For comparison sake I now use penzoil 5-20 synthetic oil. I switched from Mobil one only because penzoil has the rating required by mopar and I use mopar oil filter from walmart. I also change my oil every 5000 miles.
Overall my impressions really haven't changed. Straight highway my temp hovers around 21 which is approx 10-15 degrees lower than without it. When going up a steep hill it does raise and will fall but takes a lot more time than cooling temps. When traveling back roads 30-55mph temps are any where from 190-200 usually in the middle. I'm still happy I installed it and would recommend it.
After traveling a lot with the camper the best way to keep down temps I've found is to drive sensibly. While the truck will pull many hills at 65 mph around here it may have to jump to 45 rpms or slightly more. This is when I see my temps raise the quickest. I've found staying between 3-3.5k rpms is my trucks sweet spot. It has enough power and doesn't lag but the temps don't go up to fast. I may be going up the hill at 5 but I'm in no hurry because it's only going to change my time in minutes. Also I haven't changed the cheap China tires on the trailer so it makes me feel better going a little slower as they have a max speed rating of only 65mph. Any other questions let me know.
cooler, engine, towing, travel trailer
