Old 07-07-2013, 07:36 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
Default Airlift Lock N Lift with Airlift 1000 bags and RCX 6" kit
I've been trying to figure out how I'm going to use my Airlift 1000 bags with my RCX 6" kit when I get it. My first thought was building my own spacer out of steel or getting some UHMW plastic and glue it together to make a large spacer. Finally I decided to do a google search to see what might come up and this popped up. Airlift Lock N Lift. They are essentially exactly what I was thinking of building and will work perfectly.
http://www.airliftcompany.com/produc...er/lock-n-lift
http://www.etrailer.com/Accessories-...t/AL52150.html
Just wondering if there's any guys out there using these. Any experience you have with them would be appreciated. I'm also open to opinions/suggestions on what else to do to solve this problem if you have any ideas.
Old 07-07-2013, 11:33 PM
No experience on these and its pretty cool
But you can still use your airlift 1000 kit.
The way the airlift works is it compresses outwards so that the spring/coil does not have the ability to collapse.
The only problem is there will be a few coils not covered on a lifted truck, so those exposed ones will collapse.
The few members that I know with it, drop about 1/2" with weight in the bed or pulling a trailer.
1/2" is not bad at all.
But this kit you have in the attachment is great and we will be adding it to our site tomorrow
click here --->***Tuner and Muffler Sale*** <---click here
Old 07-08-2013, 12:08 AM
Rep:2026
Hmm... Honestly I didn't know that's the way the Airlifts worked... I thought they were helping hold up the frame in from the rear diff. Are you sure that's not right?.... I might have to go under there and check when they're inflated now to see exactly how they work....
Awesome, if you guys are adding them to the site I'll definitely order them through you when ready.
Old 07-08-2013, 01:21 AM
Positive.
Called and spoke to 2 different techs are AirLift late last year.
Those members I know who run this (after providing the info) have confirmed this to be the case.
Again, it will keep what ever coils it covers from compressing. Those that aren't covered will of course compress/collapse. So you will get 1/2" sag but not the 3-4" you get without them. Of course depending on weight you place in the bed or what you're towing
Old 07-08-2013, 02:13 AM
Rep:2026
Hmm.... interesting. I think I might still get the spacers just for peace of mind. They're cheap enough that it's not a big deal anyway.... How much am I looking at to get them through Bully's?
Old 07-08-2013, 03:31 PM
You need pricing on both the spacers and the bag Im guessing
Old 07-08-2013, 03:36 PM
Rep:2026
Nope, I have the Airlift 1000 bags and a compressor already. I just need pricing on those Lock N Lift spacers.
Old 07-08-2013, 03:41 PM
Email you..........
Old 08-21-2013, 05:46 PM
Rep:2026
Update:
Ordered these spacers from Andrew a couple weeks ago and got them installed over the weekend. Had to do a little bit of modding to make them work the way I intended them too (cut the lock tabs off the top and bottom spacer) and then I had to drill out the center hole for the bag to go up into properly. Other than that they work great, exactly as I wanted them too.
I got the kit for a 6" lift (even though RCX only lifts the back 4.5") but I did end up using all 6" of the spacers. It just fit better IMO and will keep everything nice and tight.
The one issue I ran into was my airline length... when I first installed the kit I wasn't intending to put them through a 6" spacer before the bag so it was a little challenging getting them hooked up with very little play room.
6" Lift N Lock Spacers
6 inch, airlift, lift, rcx, rough country
