Old 07-07-2013, 07:00 PM
BuckWild09's Avatar
BuckWild09 BuckWild09 is offline
Vehicle: 2007 Dodge Ram 1500 Hemi 4x4
Rep:63
BuckWild09 will become famous soon enough
Default XD Wheels
Havin a hard time figuring out this whole wheel thing.. I been looking at XD spy, revolver and rockstar II. I am going to be running a 37x13.5 tire. id like to them to stick out about 2.5 to 3". What offset would I need for 18" and 20" to get this?? haven't decided on the 18" or 20" yet. I tried figuring myself and google but no luck
3" Zone Body Lift--6" RCX-- Bils @ .5"-- 20x12 Fuel Hostages--37x13.5" Toyo MT
Old 07-07-2013, 07:11 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
The diameter of the wheel doesn't determine what offset you need, the width does.
First off, how much lift do you have? You need at least a 6" to run 37's. Even with that a 13.5" wide tire is probably gonna rub.
You'll probably want a 10" wide wheel if you're running that wide of a tire. A 20x10 -12 offset with a 13.5" wide tire will probably stick out about 3". You could go -24 offset if you want to go further out. Keep in mind the further out you go the more likely you are to rub on either the back of the inner fender or on the front valance.
Old 07-07-2013, 07:34 PM
BuckWild09's Avatar
Rep:63
ive got 6" RCX, 3" Zone BL, Bilsteins @ 2". Hopefully thatll give me enough clearance since it is a wider tire. If -12 puts me out around 3" will-24 be about 4"??
Old 07-07-2013, 07:44 PM
Rep:2026
Okay, 11" of lift, you'll clear them no problem. Lol.
A -24 is half an inch less backspacing that -12 so it would push the tire out 3.5" past the fender rather than 3".
Old 07-07-2013, 08:06 PM
BuckWild09's Avatar
Rep:63
thanks man appreciate it! just gotta figure out what style I want now
Old 07-07-2013, 08:10 PM
Rep:2026
No problem!
I know what you mean about figure out what style. There's so many options out there! What I did is look through a site like carid that has a bunch of wheels. Scroll through them all and make note of the ones that catch your eye. Narrow it down from there.
Old 07-07-2013, 08:31 PM
newfiebullet's Avatar
newfiebullet newfiebullet is offline
Vehicle: 2011 Ram
Rep:141
newfiebullet will become famous soon enoughnewfiebullet will become famous soon enough
price did it for me lol...i liked em and they were cheap so i was very happy
2011 Hemi RCSB Sport 4x4
Old 07-07-2013, 11:36 PM
Wandell's Avatar
Wandell Wandell is offline
Rep:35
Whenever trying to decide between wheel size, tire size or lift height, always go with the larger option. If you don't, you will regret it shortly.
Old 07-08-2013, 06:13 AM
Vehicle: 2011 Ram
Rep:141
^ i agree, im in that boat right now. just as well to do it the first time.
Old 07-08-2013, 06:35 PM
BuckWild09's Avatar
Rep:63
ive been looking for a while now i just cant find ones that have everything i want. I really like the XD cranks but they are only a 20x9 0 offset so theyll only stick out an inch or so(i think).. and apparently the revolvers dont come in a 5x5.5 lug but they do have a -24 offset that i want. its turning into a pain in the ass!! if you guys know of a black rim with a good negative offset let me know.. ill be digging through google some more
