Old 07-06-2013, 04:32 PM
Pike12 Pike12 is offline
Vehicle: 1998 dodge ram 2500
Trim Level: SLT Laramie
Color: Green
Pike12 is on a distinguished road
Default Bullydog tuner, hurting my truck?
Hey all, I have a 2003 ram with the hemi, I recently purchased a Bullydog gt gauge and tuner and the truck has starting acting up. At cold start or after the truck has sat a while I will turn the truck on and the rpms will surge (about 100rpm difference ). This only lasts for about 30 seconds or so. I'm wondering if its the o2 sensor or if the tuner is harming my truck. Also, after i demand some power from the truck (aka: dickin' around) the engine dogs really bad and then ill drive it for a bit and it will return to normal. i was just wondering if anyone has used this Bullydog tuner and what their experience with it was? Thanks!
Old 07-09-2013, 11:33 PM
bucks bucks is offline
Vehicle: 2004 Dodge Ram 1500
Rep:17
bucks is on a distinguished road
Easiest way to tell is pull the tuner off the truck and see if you notice any difference.
2004 Dodge Ram 1500 Hemi Sport, AWD, Muffler delete
Old 07-09-2013, 11:36 PM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
That's what I was going to suggest. Remove the tune and do the same things i.e. dicking around, and see if the truck still has issues. If it doesn't, then you know it's the tune.
Old 07-12-2013, 07:41 PM
Color: Green
I de tuned it, it runs better. Although now im missing that giddy up the tuner gave the truck, it really dogs while its in 2nd gear at about 40% throttle I was just wondering if anyone has had problems with the specific tuner brand, needless to say I selling the Bullydog tuner and going with superchips brand.
Old 07-12-2013, 11:29 PM
Rep:17
Probably a good idea. Go with a superchips or diablosport and you won't be disappointed.
Old 07-13-2013, 02:13 AM
mb power wagon's Avatar
mb power wagon mb power wagon is offline
Vehicle: 2007 dodge power wagon
Trim Level: power wagon
Rep:68
mb power wagon will become famous soon enough
if your getting "flat" spots in your throttle response, try cleaning your throttle body and check for vacuum leaks. that caused my power wagon to do almost the same thing. my throttle body was filthy and i found a small pinhole that only leaked under hard throttle conditions. but after i fixed the vacuum leak and cleaned the throttle body it was perfect. you could also try cleaning the injectors. try using seafoam once your tank is down to 1/4 and run it to almost empty to get the best effect from the seafoam. or have the injectors cleaned at a shop that won't rape you.
Old 07-17-2013, 10:49 AM
Color: Green
I have cleaned the throttle body, I do that twice a year now, I've tried the seafoam, and I've been thinking about having a shop bench test and clean the injectors.
Old 07-17-2013, 02:51 PM
Rep:68
how did you use seafoam? through a vacuum line in to the engine? that does a great job of cleaning the combustion chambers and valves but in the tank is the only way to clean the injectors. but taking it in the have the injectors done at a reputable shop is definitely the way to get them cleaned thoroughly. did you check for vacuum leaks? i have even heard of guys having issues with the intake leaking. i usually check for vacuum leaks with a propane torch. turn it on but don't light it. as you move the torch over the engine it run better as you find the leak. once you find the general area where it ran better start looking closely for where the problem is. at least that method has always worked for me.
Old 07-19-2013, 01:09 PM
Color: Green
Ill try that torch idea, I have used the seafoam through a vacuum line and the tank
Old 07-19-2013, 10:54 PM
Rep:68
the torch has never let me down...well. it did once but i forgot to put a new FULL propane tank on it. i felt like an idiot when i realized why i couldnt find the leak and noticed the propane tank was empty. lol. what vacuum line did you use for the seafoam?
programmer, rough idle, tuner
