Old 09-13-2013, 12:01 PM
APSTRAM's Avatar
APSTRAM APSTRAM is offline
Vehicle: 2012 Ram 2500 Crew Cab 4x4
Color: Deep Cherry Red
Rep:85
APSTRAM will become famous soon enough
The springs and shocks I picked up from SD truck spings and their prices are reasonable. The springs are Tuff truck TTC-1213 and are not progressive and the shocks are Bilstein 5100's. For the rear I added the superlift 1" spacer and that I picked up on ebay.
The adjustable track bar is the BD Diesel unit and is very heavy duty but it is a bit costly.
Old 09-13-2013, 12:53 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
Thanks! I'll definitely check out their website today and see what I can find.
I've seen the BD Diesel track bar online and it definitely looks better than any other one I've seen so that's the one I want to go with. BD is based out of Abbbotsford, BC (where I live) so I'm thinking I'll just drive down to their shop and see if I can get it any cheaper buying directly.
Old 09-13-2013, 03:17 PM
APSTRAM's Avatar
Rep:85
Great, save on shipping. They have plenty more for your truck so bring your check book.
Old 09-13-2013, 03:31 PM
Rep:2026
Ya, I know they have a ton; I've been through their shop before. SO many goodies! I'll have to limit myself to one thing at a time other wise I'm going to go broke really fast. lol.
Old 11-23-2014, 04:07 PM
APSTRAM's Avatar
Rep:85
A couple of weeks ago after only 15,400 miles I noticed my steering was pretty sloppy and was pulling to the left a bit so I took my truck in for a front end alignment and was told they could not do the alignment due to a bad drivers side upper ball joint. I did my own inspection and also felt a small amount of play in the outer passenger side tie rod end.
I did some of reading on this subject and decided to add a full set of Carli ball joints and replaced the tie rod end. The outcome is a tight steering wheel and the truck does not pull any more. A quick trip to the alignment shop and they confirmed that my truck is now in perfect alignment with no adjustments need and therefore no charge for checking.
Old 01-25-2015, 10:09 AM
APSTRAM's Avatar
Rep:85
Just added a set of wheels and tires. The tires are Nitto Terra Grappler G2's and the Wheels are factory 2014 Big Horn 18 inch forged.
I used a set of 2 inch Bora hub centric wheel spacers to get the tires flush with the flares.
I also installed a set of Husky mud flaps front and rear.
Old 01-31-2015, 11:41 PM
APSTRAM's Avatar
Rep:85
Picked up a BD Diesel steering box stabilizer and installed it today. Seems like good quality and installed easy. Not much difference in steering but it should add longevity to the steering system.
I also checked the torque on the wheel spacers and they were still nice and tight.
