Old 02-09-2014, 05:53 PM
Leons Leons is offline
Vehicle: 2013 RAM 1500 4x4 Laramie
Rep:30
Leons is on a distinguished road
Hello Var,
You have the 8 speed transmission, I have the 6 speed
I think that makes a huge difference!
You're truck has tons more get up 'n go...
That's where I feel it is most noticable.. at startoff
Once it rolls it does not bother me so much
A tuner for me is not an option because I ride on LPG for 95% of
the time.. there are no tunes for that.. (LPG costs less than half of
regular fuel here..)
That's why the gear change would be my only option, but as I mentioned
I'm a little lost for what exact parts I have to order..?
(by the way.. how do you get that nice signature in you're posts?)
cheers.. Leon
Old 02-09-2014, 06:31 PM
Originally Posted by Leons View Post
3.92 gears.. luckily...
Its a tad slower.. not to bad..
Would like to change to 4.56 though,
but I don't know what exact parts I have to change?
this is what I know so far..
Unfortunately, this is going to be a very difficult swap for you. In 2011, Dodge changed the rear diff, and nobody makes an aftermarket gear that fits.
You will need to have your current rear carrier machined to accept the aftermarket 4.56 gear. This is the easy part.
For the front, your ring gear is actually welded to the carrier. The only way for you to complete the front swap is to replace your front axle with 1 from an 09-11 1500 4wd. You will also need a new front driveshaft as well. From there, you can buy any aftermarket 4.56 gear which will bolt up without modification.
I know this is not what you wanted to hear, but Dodge made this a very difficult mod for the newer trucks.
Well anything is possible
I was the first 12 to get 4.56 on my truck. But I started and went from 3.55.
So you're better off than I was.
I can tell you parts you'll need but you'll need to locate a front carrier or entire differential assembly from an 09-11. Then you'll need to find a shop that can machine your rear carrier.
If you find the right shop, they can do all in house.
Difficult job will be finding the right shop. But you may already know one...
Originally Posted by RAM357 View Post
Leon,
May I suggest looking into the Diablo Sport Trinity T1000 tuner. Take it from another guy running the 37's / HEMI / 3.92. The 3.92's are the best stock config but man this tuner rocks!
I just installed the 93 octane tune yesterday and took a very short rip around this afternoon, and I gotta say it's pretty sweet. I was hitting 160 kmh on the back hwys without any work! The shifts were so smooth my wife sitting next to me had no idea what speed I was hitting!
Turning onto the main hwy after, I was hitting 7th @ 100 kmh and 8th @ 120. Folks behind you will just vanish into dust! I honestly thought the guy coming up on me (already on the hwy) as I turned onto the hwy had turned off, until I spotted the speck way back.
Me like!
Var
PS: If you don't have a local supplier (I say that because you're an ocean away) then FastnUgly @ BP (Bully's Performance) is your man! Give him a PM, and he'll take care of you.
Leon, as Var indicated. A tuner will help for now. Gears will great liven your truck up
But try the tuner first.
Plus you'll want one to calibrate those 37's to your truck.
Old 02-09-2014, 07:15 PM
RAM357's Avatar
RAM357 RAM357 is offline
R A M M S T E I N
Vehicle: 2014 RAM 1500 Sport CC Hemi
Trim Level: Sportabulous
Rep:580
RAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to all
Hello Var,
cheers.. Leon
Sorry Leon, I forgot about the LPG. But get a recalibrator then for the tires so that you can at least tell the computer what size tires you're running so you EVIC screen data is accurate etc.
Sig line - if you look under your "User CP" - "Edit Signature" is on the left hand side under setting and options. That is the area you can upload a photo (of certain dimension/file size limitations), and where you can itemize all your mods.
Var
*YES IT'S BLACK AND WHITE AND YES IT'S A SEXY THANG*
* 2014 RAM Sport CC* BDS 6" Suspension* Fox 2.5 Coil-over front * Fox 2.0 rear & Pro-Ride 3" coil* 3.92 Gearing* Fuel hostages in 20x9 +1
37x12.5R20 Pro Comp Xtreme MT2
* Diablo Sport Trinity T1000 * Cabin Air Filter
* ARH LT headers * Magnaflow catback/5" tips * 87mm Ported TB * Moroso Polished Catch Can*_QTP_electric_cutout_&_3"_turn_down * Legmaker Short Ram * S&B custom filter * Outerwears Pre-filter * Extang Solid-Fold Tonneau
Old 02-09-2014, 10:14 PM
Var
As Var mentioned. Getting your tire call rated to your truck will already make a difference as your speedo and shift points will be accurate
Old 02-10-2014, 04:04 PM
Rep:30
Hello Var and Fast 'n Ugly,
My speedometer is recalibrated, my dealer had a hypertech calibrator.
Fast 'n Ugly... I have a shop that can do the machining no problem...
1 minute walking from my house! K-A-R-S Custom and Rod Shop
I only need to know what parts to order... If you can help me with that that would be highly appreciated..
I will have to order the parts new.. since finding used parts for a RAM in Europe is impossible..
And atached... some extra hefty porn..
Old 02-10-2014, 05:42 PM
Your truck is PURE SEX!
Love it.....
Old 02-10-2014, 09:21 PM
012RAMbo's Avatar
012RAMbo 012RAMbo is offline
Vehicle: 2012 Ram 1500 CC
Rep:264
Cabin Air Filter -Debadged -14" Magnaflow -Mopar T Grip Shifter -Foxbox w/ 10" Type Rs -B Pillar tape removed -Tint matched -CST/Pro Comp 6" Lift - 35x12.50 ATZ P3 and 20x9 +1mm Fuel Mavericks -AMP Power Steps -8k HID -HEMIFEVER Tune
Old 02-15-2014, 12:36 AM
fudrock's Avatar
fudrock fudrock is offline
Vehicle: 2012 Ram 1500 4x4 CC
Color: True Blue
Rep:133
fudrock will become famous soon enoughfudrock will become famous soon enough
removed factory airride
BDS 6" coilover liftkit / Fox front and rear shocks
5" rear coils / 1" extra preload adjustment gave a level stance.
BDS dual steering stabilizers
Fuel Offroad 22"D537 Maverick wheels
Fuel Offroad 37x13.5x22 Mud Gripper MT tires
love it!..
Damn this looks really really nice!
4" BDS Lift Kit w/ 3" Rear Coil Springs and Fox Shocks - Bilstein 5100 Shocks @ 2.1 - 20x9 XD Badlands -12 Offset - 35X12.50 Mickey Thompson ATZ - WeatherTec Digitalfit Floor Mats Front and Back - Bakflip VP - 18" Magnaflow Exhaust - Debadged - Smittybilt/NFAB Stainless Nerf Bars - - Bully Dog GT - 2013 OE Projectors - Cabin Air Filter
Old 02-15-2014, 09:03 PM
Campbell402's Avatar
Campbell402 Campbell402 is offline
Vehicle: 2014 Ram 1500
Rep:73
Campbell402 will become famous soon enough
Your truck looks amazing man great job!
Old 02-22-2014, 08:33 AM
sswyers sswyers is offline
Vehicle: 2011 dodge ram outdoorsman
sswyers is on a distinguished road
After looking at this I can't wait to get my 4" bds...
