Old 06-25-2013, 08:06 PM
RAMinator13's Avatar
RAMinator13 RAMinator13 is offline
Vehicle: 2013 ram crew cab Sport 4x4
Trim Level: Sport/laramie
Color: Black beauty
Rep:43
RAMinator13 is on a distinguished road
Default Federal mt worth saving a hundred a tire!!!!
Alright guys it's time to ditch the crappy good years on my 2013 sport cc 4x4. I was going to tun the federal mt. Does anyone have these to give me a accurate review on there street/offroad ability and wear? I know they won't be the best but the price is amazing and it may be worth the hundreds of dollars I will be saving if I can get two years out of them. Also I am going to do the front bilstein level and was wondering if I could tuck some 35 under the front if I added a 2in lift to the rear as well. I'm okay with a hair of rubbing but nothing ridiculous. Or is 33/12.5 the max I can go? Thanks for the help guys
2013 RAM CC Sport 4x4 - 6spd 3.55 Anti-spin diff. MODS: 35x12.5r20 Mickey Thompson Baja ATZ - Rough Country Level 2.5 front & 1.5 rear - Airaid MXP Cold Air - Magnaflow Magnapack 4x14 & Magnaflow True Flow Y pipe mod- 20x9 Ballistic Razorbacks
Old 06-25-2013, 08:14 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
You won't need to lift the rear at all to fit 35's... just the front. You could either set the Bilsteins at 2.1" or 2.8" and clear the 35x12.5 Federal MT's no problem. The 35x12.5 Federal MT's actually measure around 34x12. Keep in mind if you go to a 12.5" wide tire with the stock rims you will need 1/4" spacers.
From what I've heard about the tires lots of people like them. Especially the price. My cousin is running them and hasn't had anything bad to say out of them. I know gonefishin776 has them and I've never heard him say anything bad either. He'd be a good guy to talk to regarding tread wear and life expectancy. Hopefully some other guys will chime in for you as well.
Old 06-25-2013, 08:19 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
I love my tires bubba.
great offroad and not obnoxious on the highway for a M/T. a hum at 30/35 which I rarely travel at for a long time. wear is reasonable, they are wearing uneven because my alignment Is effed up. but I've had them since New Years, probably 8k miles on them
and still plenty of tread
Old 06-25-2013, 08:42 PM
Color: Black beauty
Rep:43
Thanks a lot guys. I may do the bilstein or I may do a 3in front spacer with a 1.5 spacer in e rear just to get it a little higher looking. Sounds like im gonna try them. Cant beat the price. Hopefully the sidewall splitting I have heard about doesn't happen
Old 06-25-2013, 08:48 PM
Rep:2026
I'd be really hesitant to go with a 3" spacer on the front.... you're really going to be pushing your CV shaft and control arm angles. Typically 2.5" is the highest you'd want to go.... I'm running at 2.5" HBS spacer and a 0.75" TGC rear spacer and that's already putting me on the edge of too much rake IMO. A 1.5" spacer would make your truck look really raked.
Old 06-25-2013, 08:52 PM
Color: Black beauty
Rep:43
Thanks for the help. I'll do a 2.5 and. 75 like you. Just want a little rake for towing my little trailer. If I do bilstein up front. They go to 2.8 so are they safer or still pushing the limit?
Old 06-25-2013, 09:06 PM
Color: Black beauty
Rep:43
Check this out guys. Looks sweet. Its a 2.5 front 0.75 rear plus a 1.0in body.... What do yall think about this setup????
Old 06-25-2013, 09:10 PM
Color: Black beauty
Rep:43
Check this out guys... What do you think.. This link has a 2.5 front 0.75 rear and 1.0 in body... What do you guys think about this?!?!? http://www.roughcountry.com/suspensi...ram_combo.html
Old 06-26-2013, 03:03 AM
Rep:2026
The Bilsteins at 2.8" end up settling to around 2.5" or 2.6" so you're good there.
I've seen the RCX combo kit. I'm just not a fan of body lifts personally... It's just asking for fitment problems, misaligned panels, and squeezing.
If you're worried about sagging while towing your trailer the Airlift 1000 bags are a great option. For $88 you can't really go wrong.
Old 06-26-2013, 01:15 PM
RAMinator13, if you need pricing on level kits/Bilsteins or tires, let us know
