Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.2 Liter V8 > Exhaust
Exhaust 5.2L Wxhaust Discussion
Old 06-20-2013, 08:41 PM
94Ram 94Ram is offline
Vehicle: 1987 Dodge W-150 Power Ram
Trim Level: LE
Engine: 1981-1987 318ci (5.2L) LA V8 140hp
94Ram is on a distinguished road
Default 87 Power Ram Wierd Setup
Hey guys just bought my 87 power ram and I was curious so I got to looking under the truck and there is only one catalytic converter about 8" long off the driver side. There is nothing off the passenger manifold. I though this was a little odd and must be factory because there is no cut/weld marks. anyway I intend on running true dual glasspacks and I know some have done it with this year truck but to me there's absolutely no room can anyone help me by telling me their configuration or ideas for true dual exhaust on an 87 power ram shortbed. Thanks
Old 06-20-2013, 10:50 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Typically this involves ditching the stock exhausts and adding aftermarket headers after tapping and threading the air injection holes in the cylinder heads at each exhaust port. Take the stock manifolds off and you'll see what I'm talking about. Once the headers are in place and the air injection ports are plugged, the rest is easy.
Old 06-20-2013, 11:16 PM
Trim Level: LE
yeah I planned on going with header guess I shoulda been more clear what I meant was there's not a whole lot of room between the frame rail and the tranny mount cross member to run side by side pipe or stacked down the passenger side the only thing I can think of is keep the passenger side pipe route and go down in between the fuel tank and driveshaft to meet up I with the other pipe idk its deffinately going to take some brain power
Old 06-21-2013, 10:50 AM
Rep:85
Maybe this will help?
http://www.jcwhitney.com/performance...0223j1s21.jcwx
Maybe glean some ideas at least. Optionally, go with a single 3 inch pipe, splitting off to duals further back.
Old 06-21-2013, 11:58 PM
Trim Level: LE
thanks Gen1dak found this... same brand but true dual and a lot cheaper
http://www.discountexhaustsystems.co...st,universal:0)
