United Radio
Old 06-15-2013, 12:03 AM
alopez21 alopez21 is offline
Vehicle: 2012 ram 1500 sport 4X4
alopez21 is on a distinguished road
Default 2012 4x4 Wheel and tire size combo
Hey guys I'm trying to decide on what size tires to get but I'm having trouble because I don't know if I will have a rubbing issue. I want to run 22x11 wheels (-24 offset) with 305 50 r22 tires. I have 2012 sport 4x4 crew cab with hbs 2.5 leveling kit, and if some guys can get away without any rubbing on a 35x12.50 20 with just a leveling kit. I'm hoping I can get away with what I want to run. If anybody is currently running this set up or pretty close to it I would greatly appreciate y'all's input. Thanks!
Old 06-15-2013, 11:41 PM
Vehicle: 2012 Dodge Ram CC 4X4
Color: PX8 Black
It will fit as its only a 34" tire.
If you do rub, it's minimal and since you have a sport a dremel will fix that lower front valence
2014 Ram Hemi Tuning now available from Diablo Sport get yours today!
Old 06-16-2013, 05:27 AM
brandonjansen's Avatar
brandonjansen brandonjansen is online now
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:1969
brandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant future
My guess is that you'll rub on the back of the inner fender quite a bit because of the width and offset. I have 20x9 -12 offset with 35x12.5's and 2.5 HBS kit and I already had that problem. You're going to be sticking out even further which would make the problem worse.
8" BDS Long Arm Lift with Fox 2.0 Shocks | Dual Fox 2.0 Steering Stabilizer | 37x13.5 Toyo MT's | AMP Powersteps & Bedstep | Bakflip G2 | Mag-Hytec Rear Diff Cover
EST 500 hp/1268 ft-lbs at FW | H&S MiniMaxx Custom Tuned | 4" Flo Pro Stainless TBE | Sinister EGR Delete | ARP 425 Head Studs | 4.56 AAM/Yukon Gears | S&B Intake w/ Scoop
Old 06-16-2013, 03:04 PM
Thanks for the replies guys! I'm hoping it won't rub on the front but like you said its nothing a dremel won't fix lol. As for the rear it being a 305 which I believe (correct me if I'm wrong) is about .5 narrower than the 12.50, so hopefully that .5 difference won't cause me to rub in the rear. I'm hoping to see if someone out there is running this size and if possible to see how it looks like on their ram.
