Old 06-14-2013, 03:39 AM
acs0424's Avatar
acs0424 acs0424 is offline
Vehicle: 2007 Dodge Ram 1500
Rep:15
acs0424 is on a distinguished road
Default Differential Upgrade
Hey Y'all
I think this is my first actual thread I've created so hopefully it's in the right spot for the topic and all that jazz.
In any case, moving on. Found out today that my stock LSD in my Ram (2007 Ram 1500 Hemi QC Big Horn 4x4) is toast. When something breaks, it's time to upgrade it. Question is, I got no idea what I wanna do from here.
I'd like to stick with a limited slip diff as it really does fit most/all my needs. I know about lockers but don't know about lockers if you know what I mean.
I'm here today to ask you guys what exactly a good upgrade is. Budget isn't too much of an issue but I'd like to keep it sub $1000 and from what bit of looking around I've done most diffs tend to be $500-$700 so it shouldn't be difficult. So far I've found the detroit truetrac and I've also heard of the auburn diffs. I really know nothing about these things and don't know which is better, or if they both have certain pros and cons.
So regarding the diffs, basic question: What the hell should I get? I know so little about these and the internet and search functions are only so helpful. I'm always a fan of real discussion.
Part 2:
So I know whatever shop does the work will have to go into the rear end. Does this mean they'll also be able to change the gearing or is that a completely different part of the truck (very novice gearhead here). Currently I've got 3.92's and I'm wondering if upgrading to something like 4.10s is worth it. No lift on the truck, running 33" tires, and I don't particularly care about gas mileage. So part 2 question: Is doing a gearing upgrade worth it and what exactly does it do?
EDIT: Left something out of my original post - seeing as this forum section also has suspension in the name might as well post this here.
Part 3: I want to do a suspension upgrade. Not a lift per say (perhaps a level) but just an upgrade. Currently debating between Bilstein 5100s (which you all know about) or Rancho RS9000XL adjustables: http://www.autoanything.com/suspensi...0A3517561.aspx. I am aware of the price difference. Looking to do all 4 shocks. I don't need a lift really as I'm more dealing with rough back/dirt roads/paths in Maine so I want something that can just handle it better than the stock suspension. I like the Rancho's and I've heard about a certain part in the Bilsteins breaking after rough enough use although this certainly could've been special circumstances as I do not recall. So part 3 question: Ranchos or Bilsteins? Or any other ideas? I'm open to recommendations on this. No real determined budget thus far but sub $1000 is preferred.
I have done a bit of searching on the forums and the internet but like I said previously it's only so useful.
If you need to ask me anything in order to give me better info by all means please go ahead.
Thanks for any and all help guys,
Andrew
Old 06-14-2013, 06:23 AM
newfiebullet's Avatar
newfiebullet newfiebullet is offline
Vehicle: 2011 Ram
Rep:141
newfiebullet will become famous soon enoughnewfiebullet will become famous soon enough
the shitty part with gears is you have to do front and rear so that budget just wont do it.but 4.10s wold go good with the 33's. everyone i know with the tru trac loves it.
2011 Hemi RCSB Sport 4x4
Old 06-14-2013, 11:54 PM
acs0424's Avatar
Rep:15
Good to hear the good things about the tru trac. Out of curiousity do you have any idea what the approximate cost to do front and rear gears may be?
Old 06-15-2013, 01:48 AM
Depends on the shop really.
I'd say budget for $2k give or take a few hundred
Old 06-15-2013, 02:56 AM
acs0424's Avatar
Rep:15
Haha alright yeah that is beyond my budget. I can't quite spend all of my summer work money, haha. Thanks for the info.
Old 06-15-2013, 08:30 PM
Vehicle: 2011 Ram
Rep:141
ya 1k per axle is a good ballpark.
Old 06-15-2013, 11:34 PM
acs0424's Avatar
Rep:15
Thanks for all the help guys. I think I know where I'll go from here.
Old 06-16-2013, 09:54 AM
Vehicle: 2011 Ram
Rep:141
for the record if you every do swap gears you might as well go for 4.56's, truck will run like a raped ape and if you upgrade to bigger tires down the road you will see even more benifit.
Old 06-17-2013, 12:21 AM
acs0424's Avatar
Rep:15
Thanks for the tip. If I'm gonna do it, might as well do it right the first time.
Old 06-17-2013, 12:34 AM
Exactly what I always recommend to customers and do myself too. Otherwise you'll be spending more later
