Old 06-13-2013, 07:16 PM
Schmat's Avatar
Schmat Schmat is offline
Vehicle: 2010 Dodge Ram 1500 Sport
Color: Deep ocean blue
Rep:64
Schmat will become famous soon enough
Default My 2010 Lifted Ram
Hey guys this is my 2010 Dodge Ram sport 5.7l
Current
6 inch pro comp suspension lift stage 1
3 inch body lift
1 1/4 spaces
18x9 Metal Mulisha Rims
35x12.5 Pro Comp A/Ts
Bushwacker Fender flares
Tri Fold tonneau cover
Tinted Tail Lights
De badged
Bullbar
Hella 500s
Flowmaster 40s
k&n drop in filter
Painted engine parts
On board Air with 3 trumpet Train Horns
JBL 600 watt amp
2 12 inch JBL subs
Bullet Tweeters
Infinity 9602 Doors
Mopar T Handle Shifter
Blue Led interior lights
Might be forgetting some stuff
Future plans consist of... Possibly changing the shocks and putting in a coil spacer for 2 more inchs of lift, and hoping to go 40x13.5 Nitto Mud Grapplers
next season, Also have to do gears
Now question... Is there any 4th gen running 40s? If so what gears are they on and whats there lift? any thoughts on if i can clear 40s with what i have? Pics will help!!
Rob
Old 06-13-2013, 07:47 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:1946
brandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant future
Very nice looking truck! It's definitely gonna look a lot better once you step up to 40's as well. I've never seen anyone on the forum running 40's on a 1500. I know Candy08 had 38's but that's the biggest I've seen. I think he might have had a few clearance issues as well. He was running the 6" RCX kit with Bilsteins and a 3" body lift. He'd be a good guy to talk to about fitting 40's.
8" BDS Long Arm Lift with Fox 2.0 Shocks | Dual Fox 2.0 Steering Stabilizer | 37x13.5 Toyo MT's | AMP Powersteps & Bedstep | Bakflip G2 | Mag-Hytec Rear Diff Cover
EST 500 hp/1268 ft-lbs at FW | H&S MiniMaxx Custom Tuned | 4" Flo Pro Stainless TBE | Sinister EGR Delete | ARP 425 Head Studs | 4.56 AAM/Yukon Gears | S&B Intake w/ Scoop
Old 06-15-2013, 12:47 PM
Schmat's Avatar
Rep:64
Thanks for the response!
Old 06-15-2013, 08:43 PM
Asur Asur is offline
Vehicle: .
Rep:4364
Super sweet ride, love the color, there are some pics you posted you should put in the Photo's section in the 2014 Calendar submissions, there are some sweet pics of your truck that would look great in the calender, congrats on a sweet ride, very nice. Reps for sharing
Old 06-16-2013, 01:03 AM
Schmat's Avatar
Rep:64
Thank you! ill try and find that! which pics where you thinkin?
Old 06-17-2013, 03:38 AM
Ryank's Avatar
Ryank Ryank is offline
Vehicle: 2009 Dodge Ram
Rep:199
nice truck! I like it
Flowmaster 40, Magnaflow Y-pipe, K&N CAI, Leveled, HIDS, 34" Falkens, Double Din Pioneer
Old 06-17-2013, 12:00 PM
Schmat's Avatar
Rep:64
Thank you!
Old 07-26-2013, 06:50 PM
bjc24v bjc24v is offline
Vehicle: 2012 Ram 1500 quad cab 4x4
Color: Deep Cherry Red
bjc24v is on a distinguished road
love ur truck! 100 percent gonna get fender flares after seeing what urs look like! What make is ur bullbar?
Old 07-26-2013, 11:11 PM
PappaJohnRam's Avatar
PappaJohnRam PappaJohnRam is offline
Vehicle: 2003 Ram 1500
Rep:563
PappaJohnRam is a name known to allPappaJohnRam is a name known to allPappaJohnRam is a name known to allPappaJohnRam is a name known to allPappaJohnRam is a name known to allPappaJohnRam is a name known to all
Great looking truck!
Pappa John
Old 07-27-2013, 02:50 AM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
You could fit 40's under there however it is no light project to get this done. you are going to need at minimum an 8" suspension lift, 3" body lift and an aftermarket front bumper such as the Iron bull to get the clearance you will need. The next issue you are going to run into is the front IFS being able to handle it (might be ok pounding the pavement) but any kind of off roading and you are going to start snapping CV's for sure. and you are for sure going to want to run a 4.56 gear (this is the largest gear the 09-13 Ram 4x4's can run with the factory housings.
Thanks
Jeremiah
