Old 06-13-2013, 09:01 AM
scottishtornado scottishtornado is offline
Vehicle: 2012 ram laramie
Trim Level: leather
Color: silver
Rep:78
scottishtornado will become famous soon enough
Default Y pipe installed pics needed
I am about to buy a magnaflow muffler and the Y pipe for my 2012 1500.
Speaking with the guy who is going to install it he said with the bends in the factory set up and being so close to the tranny it might be a pain to add a new Y pipe. I know you guys have it done all the time and I was wondering if any of you had good pics of how you installed yours.
Many thanks in advance for your help.
Mac
Old 06-13-2013, 11:01 AM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:554
Stock Y
Maggy Y welded in with a couple $15 pieces of mandrel bent stainless steel elbows....
Old 06-13-2013, 11:55 AM
Ezekielguy86 Ezekielguy86 is offline
Vehicle: 2012 Dodge Ram 1500 5.7 HEMI
Trim Level: ST Express
Rep:71
Ezekielguy86 will become famous soon enough
I have still yet to get mine put on. Everyone around me wants a arm and leg too do it. Cheapest place wants $150
Diablo Sport Intune HemiFever 93, S&B Intake, 14" Jones Full Boar, Mag Y Pipe, 180 T-Stat, Billet Catch Can, Pioneer 5500BHS, Fox Box W/ Type R, Air Lift 1000
Old 06-13-2013, 01:05 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Here's how I did mine, got rid of the factory y pipe, the crushed pipe crossover under the transmission, and moved to allow for easier trans removal. I also originally intended to run a deep trans pan(can't do with stock crossover) but since changed my mind.
I welded most of it but left it clamped in a couple places so I can pull it all off without cutting it.
Sean
Old 06-13-2013, 05:37 PM
mexi mexi is offline
Vehicle: 2013 Dodge Ram
Trim Level: LARAMIE
Color: MINERAL GREY
Rep:27
mexi is on a distinguished road
what kind of gains are people seeing with this
Old 06-13-2013, 05:48 PM
snrusnak's Avatar
Rep:1385
It's a small gain. I did it because I could do it cheap by doing the work myself, use the pipe I wanted with mandrel bends, etc. I would have liked to get SS but I went with galvanazid as it's much cheaper. Everything from the y back is SS, but from the manifolds to the y I used galvanized(SS mandrel bends are expensive). I might make headers down the road so if I do that I'll replace with SS. Also, I'm in florida so corrosion isn't bad like up north, I think the galvanized will last a long time. I sprayed the welds with high heat paint since they burn the galvanizing off.
Another main reason I did it was just to relocate the crossover to behind the transmission.
I personally wouldn't pay a shop to use mild steel, crush bends, and charge a couple hundred bucks to install it. But I don't like to waste money...
Sean
Old 06-13-2013, 05:56 PM
Trim Level: LARAMIE
Color: MINERAL GREY
Rep:27
gotcha.... didnt notice the crushed pipe till today... i was like wtf
Old 06-13-2013, 06:10 PM
Grubrunner's Avatar
Rep:3883
I have some pictures in my Signature also.
Please remember the crushed LHS bank pipe that runs under the transmission. It's a relatively easy replacement for an exhaust shop and will improve flow.
Good luck.
Grub out!
Old 06-13-2013, 06:12 PM
Grubrunner's Avatar
Rep:3883
HERE is another thread that may help you.
Grub out!
Old 06-13-2013, 07:09 PM
Trim Level: LARAMIE
Color: MINERAL GREY
Rep:27
thanks that looks like alot better set up after
