Old 06-10-2013, 04:27 PM
PLFD53 PLFD53 is offline
Vehicle: 2012 Dodge Ram 1500
PLFD53 is on a distinguished road
Default Hemi running Rough after K&N Intake
Hey guys, my name is Joe and I'm new to Ramforumz. I was told this was a good place to get some insight about my 2012 Ram 1500 with the HEMI. I recently put in a K&N intake and the truck was running fine.. recently, however, the engine has been running rough. It almost sounds like its getting too much air. Cold starts in the morning are tough. It sounds like I put a cam in with too big a lift and it has trouble starting but only when its cold. Other times while driving the truck will jump like it receives a burst of air from the intake and then will go back to normal. Anyone have similar issues or know of a solution> Thanks, Joe
Old 06-10-2013, 04:41 PM
Asur Asur is offline
Vehicle: .
Rep:4371
Welcome to the site, well maybe you soiled your air temp sensor, or its not plugged in properly. Maybe the air temp sensor is broke. Did you oil your filter when installing and over oil it?
Old 06-10-2013, 05:46 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
What Asur said is good information ^^ Definitely check the air temp sensor to make sure it's plugged in properly and isn't wrecked.
Also, did you disconnect your battery to reset your computer after installing the intake? If not, disconnect the negative, leave it for about 10 minutes, and then hook it back up. It's amazing how many problems that seams to solve when installing aftermarket parts like a CAI.
Old 06-11-2013, 01:12 AM
Piston Slap's Avatar
Piston Slap Piston Slap is offline
Rep:42
Piston Slap is on a distinguished road
Almost sounds like a vacuum leak. The good suggestions above would be a good place to start.
Old 06-11-2013, 01:21 AM
This ^^^ is what was thinking too....
Either way, check the hose and make sure its all connected ad check the sensor and such and report back
Old 06-11-2013, 01:53 AM
madhatr02's Avatar
madhatr02 madhatr02 is offline
MOPAR or no Car
Vehicle: 2014 Ram 2500 HD
Rep:145
madhatr02 will become famous soon enoughmadhatr02 will become famous soon enough
You have to ensure that you have the sensor installed where the air flow is not blocked. Hard to describe in words but when you put it in the tube make sure the sensor is open.
Semper Fi,
Kevin
2014 2500 HD
aka "Big Red"
hemi 5.7, hemi engine, intake
