Old 06-10-2013, 02:47 PM
Nvaisvilas13 Nvaisvilas13 is offline
Vehicle: 2013 Dodge Ram
Trim Level: Outdoorsman
Nvaisvilas13 is on a distinguished road
Exclamation 2013 aftermarket HID kits
I'm looking to add 6K HIDS to the low beams and fog lights in my ram. Do I need to worry about haveing a 'bulb out' light when I put them in? And do I need to add a relay to the low beams? And should I put a relay on the fogs? And lastly I read somewhere that the 55wat fogs melt the factory lense? If anyone knows anything about that and the fix or the anwsers my questions please share.
Thanks
Old 06-10-2013, 03:02 PM
Iqudayo's Avatar
Iqudayo Iqudayo is offline
Color: Mineral Gray Metallic
Rep:563
Thanks
Ok lets see when you are dealing with the head lights (low beams) 6,000 K 55W. will work great. and in the fog lights you DO NOT want to go over 35W it so will melt the housing and also it's not needed (6,000K 35W will work great). the combination of both of them will be bright enough that you will not need more power that's the set up I'm running. check with.
retroshop web site I can't set the link for you it's shop dot retroshop dot us put that in the search it should come up.
they should be able to help you out you get a digital ballast
(secure it well) you'll be fine hope it helps.
here are pics of mine so you can see. I added projectors also
Old 06-10-2013, 03:22 PM
Thanks, I usually get my HID set ups from DDM Tuning but thanks for the advice about the fogs.... And I like the projector lights! Are thoes an aftermarket part? Or did ya get them from dodge?
Old 06-10-2013, 03:31 PM
Also, did you need a relay for your headlights? And how about your fog lights?
Old 06-10-2013, 04:28 PM
nikeman nikeman is offline
Rep:91
Instead of making a new thread about HIDs I figure I'd ask here. With my '11 you have to drill holes in the headlight housings to get HIDs in and working, I think because of all the wires or something. I do not want to drill into my housings so that's a HID deal breaker for me. I will have a '13 soon and it comes with the projectors. I'd like to put HIDs in the high beam and fogs. Do you have to drill for this? I'm sure this has been answered already but searching from my phone takes forever and this post is here already.
Thanks!
Old 06-10-2013, 05:41 PM
firemarshallvin's Avatar
firemarshallvin firemarshallvin is offline
Vehicle: 2013
Trim Level: Laramie Longhorn
Color: Black Gold Pearl
firemarshallvin is on a distinguished road
My .02.....I've done HID kit for an 09 and had no drilling. IMO 35W are fine for both and I have always used such. 55W typically require the additional power relay that I'm assuming you are referring too, are overly bright and tend to piss off more people. But just my .02 for what it's worth. I do use the DDM's as well as most of my friends.
2013 RAM 1500 Laramie Longhorn - Black Gold Pearl with all the trimmings. HEMI, 3.92, 8-Speed and Air Suspension
Add-ons:
14" Magnaflow, BAK FiberMax Tonneau, Misc Whelen Emergency Lights and Switchpak, 275/60R20 - BFG T/A KO2
Old 06-10-2013, 06:20 PM
Rep:91
So I could get the 35w in my projectors without drilling? I'd want white light and not the purpleish looking color. I think that's actually 5000k right?
Old 06-10-2013, 07:08 PM
Iqudayo's Avatar
Rep:563
The head lights are stock Dodge I opened the factory lights to install the projectors the (in the oven trick to open)
Old 06-10-2013, 07:09 PM
Iqudayo's Avatar
Rep:563
They came with the digital balests all the wiring was plug and play
Old 06-10-2013, 07:11 PM
Iqudayo's Avatar
Rep:563
Thanks!
The HID's should be plug right in haven't seen drilling hole issues. sorry.
bulb out code, fog lights, headlights, hids
