Old 06-10-2013, 02:37 PM
D.Rowe's Avatar
D.Rowe D.Rowe is offline
Vehicle: 2005 Dodge Ram 1500 Daytona
Trim Level: Daytona
Rep:121
D.Rowe will become famous soon enoughD.Rowe will become famous soon enough
Default Help with Tail Light Wiring - Tips?
I've got some custom tails to install but I'm no longer plug and play on these. So I've done some research. I have landed the Rear lighting wiring diagram so I feel fairly confident about wire colors and function.
I want to be sure I do this clean the first time so for those that have done this or for those with experience is wiring here's a few questions I'd really like to get off my shoulders before I begin this install.
1.) Given no "plug & play" anymore my assumption is that the tail light plastic harness within the truck is no longer part of the equation here and I should simply snip it off ? I know...duh...but just being overly cautious.
2.) What are a few options for making my hardwire connections besides twisting them together and covering with electrical tape. While I'm sure this would work something tells me there is a better way to do this.
3.) What are some tips/tricks/guidelines that might be good to follow with a tail light install like this?
Weather Tech mats, 12" Billet Antenna, Recon 60" LED bar, Spyder LED tailights, Map & Dome LED's, Pioneer AVH-P6300BT, Upgraded Tweeters in Dash, Cadence 8" Sub under Drivers Seat
Old 06-10-2013, 02:41 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
There are adapters that plug into the stock harness bulb location, then you can cut in to the wires in the adapter and the oem harness is unharmed.
The best connections are soldered and covered with heat shrink tubing. Heat shrink crimp connectors are the next best.
Sean
Old 06-10-2013, 04:50 PM
Asur Asur is offline
Vehicle: .
Rep:4371
Yup, nice, that's what I would do, there cheap and you don't mess up your OEM wiring.
So Ya, What snrusnak said.
Old 06-10-2013, 05:06 PM
D.Rowe's Avatar
Trim Level: Daytona
Rep:121
Where would I find these?
Old 06-10-2013, 05:12 PM
astroman54's Avatar
astroman54 astroman54 is offline
Rep:52
astroman54 will become famous soon enough
Your local auto parts dealer may have them.. But if not, then you should be able to get them through the dealer.. Also, you may be able to "customize" a wiring harness from an install kit for wiring a trailer connect plug on your truck as some of these break into the wiring to the rear lights via plug and play.
Andy
Andy
2009 Dodge Ram 1500 Sport Deep Water Blue Crew Cab Hemi 4x4
Old 06-10-2013, 08:46 PM
Vehicle: .
Rep:4371
check out ebay, got lots of stuff on there, better to wait for these over a week or so then cutting into the OEM wire harness.
here is an example of what i mean
http://www.ebay.com/itm/HARNESS-3157...f51844&vxp=mtr
you can pick up a couple of these, cut off the female and just use the male to link up your lights.
I found these in like 2 min, if you research it you might find just the male connector with wiring.
Old 06-18-2013, 10:46 PM
D.Rowe's Avatar
Trim Level: Daytona
Rep:121
Slight change of plans here...
So I am going to leave the bulbs in the EOM housing and leverage the plug and play that will exist there. I then need to tap into the various wires for the 3 new halo's installed in the OEM housing. There are 2 large red rings and 1 single white ring for reverse.
The question now becomes what is the best way to tap in here? Would t-taps work ? Can t-taps be used for ground as well? I have a ground wire coming off each of the Halo's so i'd look to combine all 3 of those and tap into the black ground past the OEM adaptor.
Old 06-19-2013, 01:40 AM
scrappy scrappy is offline
Vehicle: '12 ram 3500
Trim Level: laramie limited
Color: mineral grey
Rep:29
scrappy is on a distinguished road
t-taps DO NOT belong ouside the cab! they will cause nothing but problems with corrosion! solder and heat shrink are the BEST way to do it with crimp/heatshrink being a close second.
Old 06-19-2013, 07:49 AM
D.Rowe's Avatar
Trim Level: Daytona
Rep:121
So glad I asked this. Thank you. I'm going crimp/heatshrink here!
Old 07-14-2013, 04:23 PM
jlc41's Avatar
jlc41 jlc41 is offline
Vehicle: 2013 Ram 1500 CC
Trim Level: Laramie Crew
Color: Western Brown two tone (Hershey Bar)
Rep:39
jlc41 is on a distinguished road
Hey guys maybe you can help me. I bought the Recon Xtreme tailgate light strip. It has the 4 pin plug and 2 other wires that have to be hooked up. I need a hot 12v and I need the positive wire of the drivers side reverse light. Can I get this at the 7 pin trailer plug???
Thanks in advance.
tint, drop in bed liner, Avs window shades, Raptor bed rails, Dee Zee tail gate damper, Genos cabin air filter, Bak Roll-x cover, Weather tech mud flaps, Recon Xtrem tailgate bar, Moroso catch can, DoMore Slide Step, 5/16 Dual pin stripe, Reese lighted hitch cover, Master lock for hitch receiver, Truxedo bed lites, Hunter SS bull bar, Road Runner embroidered head rests, Plasticolor rear flaps with metal Ram logo, Mopar sill plates.
