Old 02-15-2014, 05:09 PM
drno drno is offline
Vehicle: 2013 ram
Trim Level: r/t
drno is on a distinguished road
Default borla xr1 sportsman
did this setup require any pipe expansion on either side or did the 3" and the ypipe fit in or over the setup as described
Old 02-15-2014, 06:09 PM
IBEWSteve IBEWSteve is offline
Vehicle: 2012 Dodge Ram 1500
IBEWSteve is on a distinguished road
Mine did not require any additional parts in order to fit. Everything laid out worked as planned and sounds absolutely amazing.
Old 02-17-2014, 09:33 AM
Vehicle: 2013 ram
Trim Level: r/t
did you have to adjust the tips? my tips are welded on from the factory and the pipe to the tips are spot welded and clamped.
Old 02-17-2014, 05:09 PM
I don't recall having to do anything with the tips for this install. Everything was pretty user friendly.
I have been meaning to upload a vid of the cold start with this setup since its been single digit temps this last month or so, sounds awesome.
Old 02-17-2014, 05:19 PM
Your muffler shop will make the exact cuts and weld it in correctly so that they do not have to do any work down the line...so to speak.
This is something an exhaust shop does daily and you should be ok
Old 02-18-2014, 05:39 PM
Vehicle: 2013 ram
Trim Level: r/t
is there a reason for the short pipe from the muffler to the y pipe rather than directly welding the y to the muffler and having a longer pipe on the other end ? is for a fitting adjustment ?
Old 02-19-2014, 06:47 AM
Thumper's Avatar
Thumper Thumper is offline
Vehicle: 2012 Ram 4x4
Color: Flame Red CC
Thumper is on a distinguished road
OK I have been going back and forth over a FM or Maggie. Now after hearing the amazing sound of your ride I am thinking Borla man! Wow! I love it. Just wondering, how much louder than stock is this setup, inside and out?
K&N CAI - Magnaflow Y - Borla Pro XS - Debadged - Cabin Air Filter - Parachord Interior Wrappings.
Old 02-19-2014, 09:06 AM
theGSE10's Avatar
theGSE10 theGSE10 is offline
Vehicle: 2013 Ram 1500 4WD Crew Cab
Color: Maximum Steel
Rep:33
theGSE10 is on a distinguished road
Exactly! They will make all the cuts and weld whatever pieces to make sure it all fits. IMO they made it look better than stock because the stock tip now sticks out a 1/2 from the rear instead of directly under...just makes it looks beefier.
It's just a fitting adjustment, my shop welded my y directly to the muffler and added 2 extensions to the y to make it fit back to the stock tailpipes nicely.
I'll take some pics of the setup later today.
Hellwig rear sway bar / Green filter / Borla XR-1 / Line-X / Bak Roll-X / AMI shorty antenna / Raptor 4" nerf bar / Mopar tow hooks / Moroso Catch Can / Bilsteins @ 2.1 / Fox 2.0 rear / TGC .75 rear spacer / Air Lift 1000 / Bak Box 2 /
Pics: https://www.dropbox.com/sh/ut4enlwx4fslgd8/slpdRXv6z2
Old 02-19-2014, 05:06 PM
Lincoln5.7's Avatar
Lincoln5.7 Lincoln5.7 is offline
Vehicle: 2008 Dodge Ram 1500
Trim Level: SLT Big Horn
Rep:26
Lincoln5.7 is on a distinguished road
great review and good information. im looking at getting the xr-1 as well. is it like really loud? im looking for something real loud but flow through with good performance. would you recommend this muffler?
Bullydog GT Programmer Tuner, Flowmaster 40 series, 2 Polk MM1040's, 85mm Throttle body, Volant Powercore CAI, McGaughy 2in drop shackles, 22x10 srt10 rims, CCFL Halos, Belltech Street Performance Shocks.
Soon to come: 4.56's and Pacesetter LT with Y-pipe, Cat delete.
Old 02-23-2014, 01:17 PM
theGSE10's Avatar
Rep:33
If general loudness is what you want than you don't want to go with this muffler. Its definitely much louder than stock when you floor it but I wouldn't call it one of the loudest mufflers out there. It gives a strong throaty growl but at idle and cruising you wont really hear it from the cab.
Its a muffler that, if you go to work at 5:30am like me, won't wake up your neighbors if you drive under 3000 rpm....but once you venture over that get ready to receive some angry calls
