Old 06-15-2013, 10:15 PM
Arth's Avatar
Arth Arth is offline
Color: Mineral Gray Metallic
Rep:2028
Output of one headlight as the other is down...
Chrome... in moderation.
Old 06-15-2013, 10:41 PM
Arth's Avatar
Rep:2028
Of course once I pull my other car in the way it works! Sooo whateve..
Both headlights on:
Foglights as well:
Old 06-16-2013, 09:59 AM
newfiebullet's Avatar
newfiebullet newfiebullet is offline
Vehicle: 2011 Ram
Rep:141
newfiebullet will become famous soon enoughnewfiebullet will become famous soon enough
sweet , looks great
2011 Hemi RCSB Sport 4x4
Old 06-16-2013, 11:16 PM
Arth's Avatar
Rep:2028
Outputs!!
Fogs:
Headlights:
Both:
Old 06-17-2013, 10:29 AM
Leveil22's Avatar
Leveil22 Leveil22 is offline
Trim Level: Laramie Longhorn
Color: Black and Tan
Leveil22 is on a distinguished road
Is that fogs alone? Are those projectors too? Any pics of your fogs
Old 06-17-2013, 06:05 PM
emjohn4 emjohn4 is offline
Vehicle: '12 Ram Sport CC / '02 Durango
Rep:154
emjohn4 has a spectacular aura aboutemjohn4 has a spectacular aura about
Lights look awesome! You'll be really happy with the results.
Fogs look a bit high (aim-wise) and left side rotation is a bit off.
Old 06-17-2013, 06:25 PM
Asur Asur is offline
Vehicle: .
Rep:4371
Yup, was about to say the same thing, high and off on the rotation, but apart from that, very sweet lighting
Old 06-23-2013, 06:51 PM
Arth's Avatar
Rep:2028
Yeah the fogs are a bit high... but not high enough to be a concern. I like to get the light to travel as far as possible. The projectors do a fine job of putting it to the ground. Not to mention the sharp cutoff means no glare either way.
Yeah I noticed that too about the fog...not sure anything can be done at this point though. I will even it out... eventually.
Here are just some random shots I took. I did get a new amp from JJ and now everything is working as it should.
Low beams on a small incline.
High
Old 08-19-2013, 05:34 PM
DragonElite47's Avatar
DragonElite47 DragonElite47 is offline
DragonElite47 is on a distinguished road
Arth, I would like to ask you a few questions about your headlights and fog lights if you don't mind.
I'm driving a 2012 Doge Ram 1500 Express. Currently have HIDs for my Low/High beams.
1. Do projector headlights require an other than stock housing? Or could I use my stock housing? I've noticed that they are different.
2. I've been searching around and cannot find a decent "how to" for fog lights. How easy are they to install?
Looking forward to your replies! Thanks in advance and Semper Fidelis!
2012 Dodge Ram 1500 Express~ K&N 63 Series Cold Air Intake, Flowmaster Super 40, HID 8k 55w
Old 11-06-2013, 12:58 PM
pilotalex's Avatar
pilotalex pilotalex is offline
Vehicle: 2014 Ram 1500 Diesel
Trim Level: Longhorn
Rep:52
pilotalex will become famous soon enough
1) Nope you can use the stock housing as I did in mine. The fxr projector is 2.5" and our stock projectors is 3" Many guys will half as it and leave a gap. You need another bezel to hide the space. Check out my thread. I would also recommend runing a OEM balast/bulb system to take the most advantage. Im running 4300K Phillips D2S with a Mishimoto ballast system,
2) Fog lights have lots of room but the are bit harder to install. Im in the process of installing FXR fog lights and I will let you know step by step. It is winter though lol so im being lazy.
