Old 02-15-2014, 07:31 PM
Ben12CCSport Ben12CCSport is offline
Vehicle: 2012 Crew Cab Sport
Ben12CCSport is on a distinguished road
Originally Posted by 012RAMbo View Post
Those wheels look pretty good! I would do 20's, but that's my personal preference. Post up some pics when you get it done! Looking to add to my lift pretty soon as well.
Thanks for the reply. Searching for the right 2wd lift has been more work than I thought it would. Definitely will have to get a tuner of sorts shortly also so I can adjust for the wheels and get some power and mpg back. Just have to figure out which tuner.
Old 02-15-2014, 07:55 PM
BLK14Spt BLK14Spt is offline
Vehicle: 2014 Ram 1500
Trim Level: 2WD Sport Crew Cab
BLK14Spt is on a distinguished road
Does any manufacturer make a 2" leveling spacer for the front that actually bolts compared to just placing it on top of the strut? The only ones I have found are all four 4x4 and not 2WD. If not, what is the best 2" leveling spacer out there? Daystar, CST, readylift?
Old 02-16-2014, 09:02 AM
012RAMbo's Avatar
012RAMbo 012RAMbo is offline
Vehicle: 2012 Ram 1500 CC
Rep:264
The strut assembly is only on the 4wd. We have a coil over style on the 2wd. The only way to lift the suspension without the spindles is a coil spacer. And you are going in the right direction with lift size and the companies. Those are the most popular companies, I believe Fat Bobs makes one for 2wd? Not sure on that one though. And of course you have the generic brands on Ebay, which work fine for most guys. But I would not go above 2'' and maybe 2.5'' max. I have seen many threads where the 3'' maxes out the shocks and gives a terrible ride. And if you put on longer front shocks, it will allow the coil bucket to hit the UCA. Not good.
Cabin Air Filter -Debadged -14" Magnaflow -Mopar T Grip Shifter -Foxbox w/ 10" Type Rs -B Pillar tape removed -Tint matched -CST/Pro Comp 6" Lift - 35x12.50 ATZ P3 and 20x9 +1mm Fuel Mavericks -AMP Power Steps -8k HID -HEMIFEVER Tune
Old 02-16-2014, 09:27 AM
012RAMbo's Avatar
Rep:264
Definitely not too many options for us 2wd. There is a newer company called Maxtrac making lifts now also. Do some browsing in the engine mod section. Most guys run the Diablosport, Bully Dog or the Super Chips. I am running the Diablosport with Hemifever tune and love it.
Old 02-16-2014, 03:31 PM
molina425's Avatar
molina425 molina425 is offline
Vehicle: 2012 Dodge Ram 1500 Sport
Color: Black-PX8
Rep:19
molina425 is on a distinguished road
Can you add to the CST 7" lift kit?? I need to level the back and go TALLER all the way around also. Ive been running it for some time now and NEED taller!! It looks pretty good just NEED more. Any have any info on this?
Old 02-16-2014, 04:29 PM
012RAMbo's Avatar
Rep:264
Great looking truck Molina. The only way you could make the rear taller is getting just the rear lift components that comes from a 4wd lift kit, like the RCX, that has taller replacement coils. Then you could add a 1-1.5'' coil spacer to that and get a total of around 6-7'' out back. And to add total overall height to your truck, you would have to go with a body lift. 1.25 - 3''. You could research the 4wd kits and see which ones come with the taller replacement rear coils, and see if they could sell just the rear. Would probably be dang near as much as the full kit itself. What are the specs on your wheels and tires? Looks good.
Old 02-16-2014, 11:43 PM
molina425's Avatar
Color: Black-PX8
Rep:19
Thanx for the help and suggestion. I honestly dont remember to much about it anymore now ive had it all almost a year. But I know the tires are 35-12.5-20. Wheels are 20x9 and I think its a zero offset.that sounds about right but not 100%.
Old 02-17-2014, 12:00 AM
fastNugly @ BP fastNugly @ BP is online now
What he said.... However RCX 4" does not have rear coil.
So you'll need BDS or Zone 3" rear coil
Wheels are 20x9, 0 offset Moto Metal 962 on 35" Nitto Trail Grapplers
Old 02-17-2014, 12:03 AM
molina425's Avatar
Color: Black-PX8
Rep:19
Thanx for the help there Fast I wasnt sure on the exact setup of what I have anymore.lol Well if I was to order this rear coil would I remove the spacer thats currently back there and just put the coil?
Old 02-17-2014, 03:18 AM
What is your rear setup. Can't remember it either.
