Old 06-05-2013, 02:10 AM
Canadian Hemi Pride's Avatar
Watch it crash and burn
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2793
Default Guide to install LED's behind the grill.
So I have had a few people ask me how to install the led lights behind the grill like I have, So i decided I would make a guide to the simple procedure.
Pic=
So first the supplies needed.
(1)Tube fuse and cover with wiring, make sure it is fast blow..(recommended to buy extra fuses as I did blow a few during set up and had to test different amp fuses to find the proper one.. I believe it is 10amp in mine now).. if 10 amp doesn't work.. Try different sizes. http://thumbs1.ebaystatic.com/m/myQy...6vvagw/140.jpg
(2)Led strip, weather proof.. either 2 12" or a 24"( 24 is easier for wiring).
http://www.canadiantire.ca/AST/brows....jsp?locale=en
(3) Toggle Switch=15amp 12V
(4)14 gauge wiring
(5) electrical tape
(6) connectors, Both hoops and wire to wire connectors.
(7) wire crimpers, cutters
Sooo.
I ran a wire(4) from the battery to the fuse(1), from the fuse(1) through the firewall (went through main grommet with wiring(4)) to a switch(3) that I mounted inside.. then from the switch(3) a wire(4) back through the firewall all the way to the light strip(2).. I mounted the light strip(2) on the horizontal pillar with the hood latch on it right infront of the rad... and then from the light strip(2) I ran a wire(4) for a ground for the leds to the truck, I already had a ground set up for my HIDS, but any strong metal place would work. I made sure to use plenty of electrical tape to wrap all connections, and used zipp ties to secure the LED's(2) to the horizontal pillar incase the double sided tape ever gives out.
It is fairly simple to do.. I reconmend being gentle on the Led's wiring because I noticed that the saudering wasn't the best and could probably be pulled out easily if not taking care during set up. It is a lot easier then how it sounds.
Feel free to ask any questions or to see closer pictures as I will answer as fast as possible.
Tow mirrors up for the haters
Old 06-05-2013, 02:27 AM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
Pic=
(4)14 gauge wiring
(5) electrical tape
Sooo.
nice write up and 100% agree with being gentle with the led's they are not very forgiving.
Old 06-05-2013, 02:57 AM
Trim Level: SXT 4x4
Rep:2793
Thanks a lot.. And sorry I forgot but I meant to mention that you were the one who gave me the idea and offered some tips a while back.
Old 06-05-2013, 06:18 PM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
Default Nice Job!
(4)14 gauge wiring
(5) electrical tape
Sooo.
Nicely done CHP. Rep points for the write up. Very articulate and to the point with pictures and numbers. Easy step by step instructions.
Old 06-05-2013, 06:26 PM
Trim Level: SXT 4x4
Rep:2793
Thank you.. I was trying to get some pictures of the actually set up in daylight but was on the forklift all day at work and leaving right now to attend my brothers graduation.. Hopefully tomorrow.
Old 06-06-2013, 12:02 AM
highlandchef's Avatar
Conventional Eccentric
Trim Level: SLT Big Horn
Rep:220
Nice post and great tips!
Old 06-06-2013, 12:08 AM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
very nice reps for you
Thanks
Jeremiah
Old 06-06-2013, 10:09 PM
Danzanzio's Avatar
Danzanzio Danzanzio is offline
Vehicle: '05 Dodge Ram
Color: Atlantic Blue
Rep:86
Danzanzio will become famous soon enough
Great write up man! I'm diggin' the white ones behind your grill. I've been contemplating on putting blue ones behind mine for a while now.
Old 06-06-2013, 10:16 PM
Trim Level: SXT 4x4
Rep:2793
Thanks.. I have a 12" strip that I am hoping to install in a gap above my cupholders so I will be able to see them at night. They will be tucked away and unseen until I turn them on.. Just need time and eithor nice weather or access to my shop.
Old 06-06-2013, 10:19 PM
RansRAM's Avatar
RansRAM RansRAM is online now
Addicted to the Z
Color: PX8 Black
Rep:2471
Agree, excellent writeup and pics, I may just have to put some on my truck now.
