Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > Bullys Performance
Bullys Performance Stop by Bully's Performance for all your Performance, Appearance and Accessories! Helping enthusiasts Mod their Ride is what we do best :). Need to pass mod idea's by or get a Professional opinion? No beating around the bush, no high pressure sales...Just simple honest recommendations and truth from a fellow RAM owner/enthusiast. We will make sure you check out with a smile on your face knowing you made the right decisions on your mods purchase(s)! Stand by us and we will stand by you! Email: sales@bullysperformance.com Phone (USA): 855-432-FAST Phone (Canada): 855-FAST-CA1
Closed Thread
Old 06-03-2013, 12:06 AM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
Smile RansRAM, My Bully's Performance Build Thread
This will be my Bully's Performance build thread of my RAM moving forward.
All Future Modifications will be posted here....
Started off with a Brand New 2010 Sport Quad Cab 4x4 as pictured below:
Modifications to date:
Exterior:
- 20% front, 35% rear and sliding window tint
- partial de badge (RAM removed from doors)
- 8" Stubby Antenna
- OEM colour matched fender flares
- LED Taillights
- Recon smoked 3rd brake light
- black honeycomb grille (replaced chrome slats)
- Custom Mopar Emblem
- Leer 700 series colour matched bed cover
- Recon Xtreme Tailgate Lightbar
- Mopar Black Aluminium Side Steps
- Mopar Anti-Theft Valve Caps
- Mopar Front Tow Hooks
- Mopar Bug Deflector
Engine/Performance:
- K&N Drop in Filter
- Billet engine dress up kit (Red)
- Billet Catch Can
- Flowmaster 40
- SuperChips Cortex Tune
- Custom Painted Engine Cover
Suspension (To Come):
- Bilstein 5100 Levelling Shocks
Interior:
- LED Dome and Map Lights
- Weathertech DigitalFit
Media System:
- RBZ with Lockpic and Front/Rear Cameras
Other:
- Under bed rail LED lighting
- 4,000k PIAA Headlights
- 4,000k Putco Fog Lights
- Painted Calipers (Red)
We all love pictures so here are before and after pics
Picked her up on March 19th 2010
And here is how she looks today
Old 06-03-2013, 01:47 AM
Can't wait to see her leveled
Old 06-04-2013, 01:14 AM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
Gonna be good can't wait to see more pics!
thanks
Jeremiah
Old 06-16-2013, 09:21 PM
RansRAM's Avatar
Addicted to the Z
Color: PX8 Black
Rep:2471
Talking
My RAM is Levelled now, Bilstien 5100's installed. My Fathers Day Project. Below are some pics of the installation sequence and a final shot with the new stance.
(Disclaimer, what follows are the steps I did to install the Bilstiens however I stress that anyone doing this please make sure you are confident with the process. Removing the struts with an improperly compressed spring can be extremely dangerous, if you are unsure please have it done by a professional. I assume no responsibility for anyone attempting this job on their own)
First is to remove the tires and make sure the truck is secure on jack stands.
Step 1, remove brake caliper and suspend securely with wire twine.
Step 2, Remove the upper stabalizer bar bolt.
Step 3, Remove the outer tie rod ball joint bolt.
Step 4, Remove the upper ball joint nut and tie it up with some wire twine.
Step 5, Remove the lower strut assembly bolt and nut and the three bolts from the upper strut tower.
Step 6, Using a pry bar and second pair of hands pry down on the lower control arm and remove the entire stut/spring assembly.
Step 7, Compress Spring and remove the OEM Strut. Remove lower plate from the OEM strut. Set the clip on the Bilstien to the desired position (I put mine on the second from the top for a 2.1" lift). Reassemble the Bilstien strut with OEM hardware with new end nut and washer exactly as shown in the following picture. Note that to get the new nut on I had to further compress the spring very carefully.
Note the location of the washer is under the upper plate and use the new nut supplied with the Bilstiens. This picture shows the proper position of all parts needed for assembly with the Bilstien.
Step 8, Install the entire assembly and replace all bolts in the order they were removed. Lower Strut Bolt, 155 ft lbs. Upper tower bolts 40 ft lbs, Upper ball joint nut 40 ft lbs plus additional 200 degrees, Upper stabilizer bar nut 20 ft lbs, Tie Rod End Ball Joint Nut 45 ft lbs plus additional 90 degrees. Note the picture shows the drivers side following installation.
Step 9, re-aim the headlights. Note I put tape on my garage door showing the pre-lift aiming location.
Before
After
AND HERE IS HOW SHE SITS NOW
Going for an alignment on Thursday.
Old 06-16-2013, 09:34 PM
Randy, truck looks amazing leveled
Do you notice it leveled from inside while driving.
Old 06-16-2013, 09:38 PM
RansRAM's Avatar
Addicted to the Z
Color: PX8 Black
Rep:2471
Talking
Thanks for the reps and yes I do notice it sitting higher from the inside. I was worried but it still fits in my garage Thanks so much for helping me get these, Bullys Performance is #1
Old 06-16-2013, 09:41 PM
It better still fit.
If my truck fit length wise, I would have been able to get my truck with my lift on 35's in the garage.
Old 06-23-2013, 10:43 AM
naturecannon's Avatar
naturecannon naturecannon is offline
Vehicle: 2012 Ram 1500 Quad
Trim Level: Bighorn
Rep:286
naturecannon is a jewel in the roughnaturecannon is a jewel in the roughnaturecannon is a jewel in the rough
I noticed more hood view when I first leveled mine.
Bilsteins 5100, Magnaflow 18, Lines X liner, Airlift 1000, Toyo Open Country A/T II, Cabin Filter, Bully Dog, Billet Catch Can, 3.92, Low Profile ToolBox, Front Cab Window Tint
Old 07-04-2013, 11:03 PM
RansRAM's Avatar
Addicted to the Z
Color: PX8 Black
Rep:2471
Smile
DeeZee Tailgate Assist Installed, another great mod thanks to Bully's Performance. Here are a few pics of the installation sequence. This product performs great and was super easy to install.
Install lower strut nut into existing opening in the tailgate.
Install the lower ball joint included with the kit.
Remove the existing upper cable bolt and replace with new ball joint from kit.
Attach the lower strut to the newly installed ball joint.
Remove existing retainer from the cable to tailgate attachment point.
This is how the completed job should look with the provided cable clip which avoids binding.
Old 07-04-2013, 11:18 PM
This one is far better quality than the Ezdown tail gate assist I have that has now rusted.
I'll be switching mine as well...
Thanks for the write up
If I can give reps, I will do so now
**Edit - was able to give you reps
Closed Thread
