Old 05-31-2013, 12:41 PM
2012ramsportellis's Avatar
2012ramsportellis 2012ramsportellis is offline
Vehicle: 2015 dodge powerwagon
Trim Level: power wagon
Color: blue streak pearl coat
Rep:94
2012ramsportellis will become famous soon enough
Default Has anyone else had problems with the rear driveshaft shuttering after rcx 6" lift on 2012 ram1500
I recently had a 6" lift installed on my 2012 ram 1500 . from day one i have had a shutter in my drive line fr 0-20 km/hr . its appears to be getting worse since the addition of 37" tires . i have contacted rough country and they sent me out a 2nd set of front differential drop brackets which lowered the angle on the front driveshaft and on my cv shafts which are almost %100 straight . , shop installed them and it never helped with my issue . Since then the shop basically tells me there is nothing they can do to help me out and this is the first case they had with an issue like mine . So iam left with a brand new truck that feels like its going to shake its self apart at low speeds . I need to get this resolved . i have had several people look at this for me and they tell me its the rear drive shaft . the shaft was removed and all u joints were checked and they are perfect since the truck only has 9xxx kms , and with only 2000kms on the lift . wondering if anyone out there with a 09-13 ram 1500 has had a similar issue involving the rear driveshaft with the 6" rcx kit ?
RCX 6" RCX 1.25" bl Bilsteins at 1.4 Mufflex 18" go-rhino dominator 2 side steps
Old 05-31-2013, 02:23 PM
Rep:94
Default pics
Here are a few pics of the rear pinion angle and reartrac bar drop bracket and also where the drive shaft enters the transfer case . measured fr the inner fender well to the outside of both tires got 1/2 in difference . drivers side 14" passengers side 14 1/2 " . appears my axle isnt centered ..
Old 05-31-2013, 02:49 PM
Ram725's Avatar
Ram725 Ram725 is offline
Vehicle: 2012 Ram 2500 4x4
Rep:347
weird. I never had this. Maybe someone will chime in with experience on this issue
SOLD: 2012 Ram 2500 CTD 4x4
Old 05-31-2013, 03:38 PM
Rep:94
I sure hope someone has some imput !
Old 05-31-2013, 04:42 PM
candy08's Avatar
candy08 candy08 is offline
Trim Level: Sport 4x4
Rep:213
I had this issue for 40k miles...all I can tell you is pull that lift off or get rid of the truck like I did.
I replaced the entire rear lift 3 or 4 times even with Upgraded aftermarket crap, swapped tires 3 times and rims twice...never helped my issue.
[CENTER][SIGPIC][/SIGPIC]
Old 05-31-2013, 05:56 PM
Ram725's Avatar
Rep:347
Oh how I miss your imput every day
Old 05-31-2013, 08:46 PM
candy08's Avatar
Rep:213
Sorry bro, I could fluff it up or smoke and mirror it like most of you clowns...just telling OP my personal experience of 2.5 years and 42k miles with my shit lifted...conclusion it's junk
I miss you too boo
Old 05-31-2013, 09:31 PM
chadster21's Avatar
chadster21 chadster21 is offline
Vehicle: 2012 dodge ram
Trim Level: sport fully loaded
Color: charcoal grey
Rep:108
chadster21 will become famous soon enoughchadster21 will become famous soon enough
^^ good to have you back
6'' rcx lift, 1.25'' rcx body lift, pro comp adjustables at 2.75'', 1.75'' tgc coil spacer. 37'' toyos on 20'' fuel hostages. mufflex 14 cai
Old 05-31-2013, 09:42 PM
SeaDodge SeaDodge is offline
Trim Level: ST Express
Color: Mineral gray
Rep:16
SeaDodge is on a distinguished road
To me it looks like your yoke going into your transfer case is bent? Maybe it's an illusion, but here's a pic of mine and it looks straight compared to yours.
Old 05-31-2013, 09:57 PM
aedwardzo aedwardzo is offline
Vehicle: 2009 Dodge Ram
Color: Light Graystone
Rep:57
aedwardzo will become famous soon enough
it seems like everybodys got some sort of problem with their lift... shuttering, wobble, rubbing, etc...... I have had zero issues with my setup so far, knock on wood. good luck man hope you can get that shit solved
mods..... Too much to list! check my mod list!
http://www.ramforumz.com/member.php?u=58666
