United Radio
Old 05-31-2013, 11:29 PM
Thebestestdrummer's Avatar
Vehicle: 2001 Dodge Ram Sport
Rep:529
if you guys want an update, i bought the isolator. I thought i could just stick it before my amp, but i had to connect it to the back of my stereo instead, had to take that out and connected it. the instructions ere terrible but it clearly said if no sound came out of the amp after hook up, ground the two wires that came to it with the same ground (it was worded weird though). so i tested it, no sound! i had other conflicts so it had to wait untill now. took the radio back out, grounded it to the battery. and it works. its very quiet compared to what it was, but it works.
thank you very much for your help.
Air horn "AHHOOOGA" horn,
Green Interior LEDs
Old 06-01-2013, 12:11 PM
bolo1g2 bolo1g2 is offline
Trim Level: Crew Cab Big Horn
Rep:19
bolo1g2 is on a distinguished road
Glad it worked out. And for the record, I've never been a fan of grounding to the battery. I'd rather have a shorter wire run to the frame and scrape the paint for the ground. Just my style of install. But glad it worked.
engine, ground, noise, playing, subs
