Old 05-22-2013, 11:01 PM
ADA16 ADA16 is offline
Vehicle: 2012 ram 1500
Trim Level: express
Rep:43
ADA16 is on a distinguished road
Default Fuel Octane Rims
Hey guys, does it matter what bolt pattern i get, because i am looking at a 12mm off set rim and want it to be hub centric because the stock rims are hub centric, and the only bolt pattern they have is 6x5.5. What does this mean and does it matter?
Thanks
Old 05-22-2013, 11:07 PM
madhatr02's Avatar
madhatr02 madhatr02 is offline
MOPAR or no Car
Vehicle: 2014 Ram 2500 HD
Rep:145
madhatr02 will become famous soon enoughmadhatr02 will become famous soon enough
I may be not understanding but if you are asking if those rims will fit your truck the answer is no. Dodge has 5 lugs that hold the wheel on and those rims have 6 lugs.
Semper Fi,
Kevin
2014 2500 HD
aka "Big Red"
Old 05-22-2013, 11:11 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
Yup, exactly what madhatr02 said. You need 5x5.5 (139.7) bolt pattern.
Old 05-22-2013, 11:39 PM
I push the skinny pedal
Rep:3277
The only way you'd be able to run 6-lug wheels is if you get a lug adapter which will have to be at least 1.5" thick, it's much easier to run 5-lug wheels.
Kurtis
Old 05-23-2013, 04:05 PM
Trim Level: express
Rep:43
Ok thanks for the help everyone.
Old 05-23-2013, 04:13 PM
Trim Level: express
Rep:43
What about 5x150mm bolt pattern?
Old 05-23-2013, 05:03 PM
ARFF65 ARFF65 is offline
Vehicle: 2013 Ram
Rep:23
ARFF65 is on a distinguished road
The truck is 5x5.5 the metric equivalent would be 5x139.7mm I believe, the only wheels that will fit will have that bolt pattern.
Old 05-23-2013, 05:10 PM
Rep:2026
Originally Posted by ARFF65 View Post
The truck is 5x5.5 the metric equivalent would be 5x127mm I believe, the only wheels that will fit will have that bolt pattern.
Nope, 5x5.5 is 5x139.7 in metric as I stated in my last post.
Old 05-23-2013, 05:28 PM
Vehicle: 2013 Ram
Rep:23
Sorry, didn't read up. Corrected.
Old 05-23-2013, 05:53 PM
Trim Level: express
Rep:43
Ahh got it. Thanks again!
