Old 05-21-2013, 01:02 PM
rjmlakota's Avatar
rjmlakota rjmlakota is offline
Trim Level: Sport Crew Cab
Color: Mineral Gray Metallic
Rep:18
rjmlakota is on a distinguished road
Default LT 10 Ply and 3.55 gears
I'm thinking of purchasing the Toyo Open Country AT2's in 10 ply for my 2013 Sport. Will I have any issues running these with 3.55 gears vs the tires that came with the truck?
Thank
Old 05-21-2013, 01:26 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
Are you sticking with the stock size or going bigger?
Either way you will lose a bit of power and fuel economy because of the increased weight of the tire. If you go with a larger size as well there will be a more significant drop of both. But I wouldn't let that stop you from doing that. I'm running 35x12.5 Toyo MT's on my 4.7 with 3.55's and it drives fine to me. Yes it takes a lot more fuel to get it going (especially up hills) but it's not near as bad as I thought it would be. I'm getting around 15.5-16 MPG with the tires so far. Which isn't bad at all.
Here's a link to my thread about the tire install and a bit of a review. You might find some of the information interesting.
http://www.ramforumz.com/showthread.php?t=141365
Old 05-21-2013, 02:05 PM
rjmlakota's Avatar
Rep:18
Thanks for the link!
I'm sticking with the stock rim, however the tire is slightly taller then stock. I believe they are LT285/55R20.
Old 05-21-2013, 02:08 PM
Rep:2026
A 285/55R20 comes in at 32 5/16" which is slightly shorter than stock (33")
With that set up you shouldn't notice too much of a difference. It will feel very similar to how it does with the stock tires.
Old 05-21-2013, 02:28 PM
rjmlakota's Avatar
Rep:18
I'm having them installed today. I will have to double check the size. I know they are slightly taller then stock.
Old 05-22-2013, 01:38 AM
You'll notice maybe 1/2 a MPG loss, but doubt you'll see anything
Old 05-22-2013, 10:19 AM
rjmlakota's Avatar
Rep:18
They are LT275/65R20
Old 05-22-2013, 11:26 AM
This is a hair over stock and you will be ok.
Old 05-22-2013, 11:30 AM
rjmlakota's Avatar
Rep:18
They ride nice! Hooked up my GPS and the speed is the same. I'll have to see how the MPG is once I fill up next time. Now I just need to purchase a leveling kit.
Old 05-22-2013, 11:45 AM
Id do the Bilsteins.....and we can provide them to you
