Old 05-21-2013, 02:44 AM
j3andit j3andit is offline
Vehicle: 2013 Dodge Ram
Trim Level: Express 4x4
Rep:18
j3andit is on a distinguished road
Default not sure..need advice
so i cant decide on what way to give my truck some lift..
read about the rcx 3.75
and also read about getting bills 5100s and setting at 2.1 and putting on rcx 1.25 body lift
will both lifts clear 35x12.50 ???
ill be using aftermarket rims so im assuming ill need 0 offset right???
whats the pros and cons of both lifts???
Old 05-21-2013, 02:59 AM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
Yes, with either of those set ups you'll clear 35x12.5's no problem. I'm running 35x12.5 Toyo MT's on just a 2.5" level and 0.75" rear coil spacers with no problems.
For aftermarket rims you will need at least a 0 offset. But you can go more negative if you want to. They will just stick out further. I'm running 20x9 -12 offset wheels. Here's a link to my thread about my install with lots of pictures for you to take a look:
http://www.ramforumz.com/showthread.php?t=141365
Out of those two lift options I'd definitely recommend the Bilstein's with the 1.25" body lift. IMO the Bilsteins are the best way to level the front of the new Rams and provide you with a better ride quality than stock. And for the price difference between the RCX combo kit and the Bilsteins I'd definitely go Bilsteins. The only spacer I would recommend doing over Bilsteins is the Hell Bent Steel one and only for people who are looking for the cheapest option.
Old 05-21-2013, 01:20 PM
Rep:18
ok thanks buddy!
