Old 05-21-2013, 12:04 AM
hemmi's Avatar
hemmi hemmi is offline
Vehicle: 2008 Dodge ram 1500
Trim Level: TRX4
Color: Blue
hemmi is on a distinguished road
Default Rough Country 4 inch lift 35's Rubbing WARNING
I recently took my truck mudding for the first time after installing the lift and tires. Rough country claimed that the lift would clear 35's with the 4 inch lift but I guess not. The rear passenger side tire rubbed the wheel well causing some damage to the truck paint cracking and chipping and some mangled metal. I don't know what to think about it im a little pissed tho.
Old 05-21-2013, 12:21 AM
OUCH!
Question for you.....
What rims are you running?
Width? offset?
They do say 35's but its also relevant to the offset and rim width you are running.
But I'm sure you know this already but still curious to know
Old 05-21-2013, 12:55 AM
hemmi's Avatar
Trim Level: TRX4
Color: Blue
I have the kmc addicts with 4.5" offset and 20x9. The tires are 35x12.5x20.
Wonder if rough country will do anything? Probably not my own stupidity.
Old 05-21-2013, 01:12 AM
To me....that is what they will point out.
I hate pointing out the bad news...but that is what I believe they will tell you....
Basically your wheels are the in correct offset for their lift
Their site does say 35's but they do also say 5.5" back spacing which I believe is a +10 or there abouts.
Usually 5" backspace will be ok too. But 4.5" brings your wheels out to the point where it lines up with your fenders and does not have the ability to tuck in the wheel well
I hope there is a positive resolution to this though
Old 05-21-2013, 01:13 AM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
You rubbed with the rear tire?? That seems really weird. I'm running 35's with a 2.5" level and 0.75" rear coil spacers with no rubbing. Especially on the rear....
Old 05-21-2013, 01:21 AM
He did to mudding, so prob had quite a bit of flex
Old 05-21-2013, 01:31 AM
Rep:2026
Ya but even at that, you wouldn't think it would flex THAT much. There's quite a gap there. Plus then the backspacing really has nothing to do with it, even it he did have the backspacing recommending by RCX it probably still would have happened.
Old 05-21-2013, 11:10 AM
hemmi's Avatar
Trim Level: TRX4
Color: Blue
There was also rubbing on the inside of the wheel well without 4.5" back spacing it would have rubbed without nearly as much travel.
Old 05-21-2013, 11:21 AM
Ahhh! Got it!
Then you have reason to question them
Old 05-21-2013, 11:22 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
damn u must have been flexin around hard son...
were u just mudding? u had to have been crawlin over some stuff
