Old 06-04-2013, 05:32 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:1969
brandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant future
I'm assuming you're talking about the kit that came with the 1.75" rear coil spacer as well? Does that spacer have a solid plate above the coil? It's not open to above? I'm running the Top Gun Customz 0.75" coil spacers and mine are open (link below with some pictures).
http://www.topguncustomz.com/p-6526-...t-spacers.aspx
The coil spacer should not change anything to stop you from running the bags other than you possibly not being able to run the airline through it if it has a solid plate rather than a hole (which is what I'm assuming Rough Country as done). You could probably just drill a larger hole in the plate on your spacer to allow the airline to run through it.
8" BDS Long Arm Lift with Fox 2.0 Shocks | Dual Fox 2.0 Steering Stabilizer | 37x13.5 Toyo MT's | AMP Powersteps & Bedstep | Bakflip G2 | Mag-Hytec Rear Diff Cover
EST 500 hp/1268 ft-lbs at FW | H&S MiniMaxx Custom Tuned | 4" Flo Pro Stainless TBE | Sinister EGR Delete | ARP 425 Head Studs | 4.56 AAM/Yukon Gears | S&B Intake w/ Scoop
Old 07-10-2013, 05:44 AM
jello03825 jello03825 is offline
Vehicle: 2012 Ram 1500 Express
Trim Level: express
jello03825 is on a distinguished road
Nice truck, I have been thinking about putting air lifts on mine. Do you get any rubbing with the -12 offset wheels
Old 07-10-2013, 12:12 PM
Rep:1969
I'm a little confused by your post.... the Airlift bags really have nothing to do with my wheel offset. Typically rubbing issues with larger tires and more negative offset wheels are always on the front because they turn. The back is never an issue. Are you maybe meaning does my truck squat enough in the back to hit the tires?? Because if so, that's a definite no. It does not get that low at all. Especially with air in the bags.
Old 08-21-2013, 03:39 PM
JDPatrick's Avatar
JDPatrick JDPatrick is offline
Vehicle: 2013 ram 1500 (4x4)
Trim Level: Tradesman/Express
Color: Billet
JDPatrick is on a distinguished road
Kinda just scrolling through the images posted I see this one
http://s1311.photobucket.com/user/br...799_n.jpg.html
and it says 2.5" leveling kit installed. I am perfectly OK with that look until I can afford the new tires without giving my wife a stroke! That looks great, I absolutely love all the stuff you've done with your truck man.
Old 08-21-2013, 03:56 PM
Rep:1969
Yes, leveled is definitely better than stock. Even with the small wheels and tires. And it only goes up from there.... literally
Thanks! It's definitely come a long ways in the past 10 months. I'm definitely happy with it.
Old 08-21-2013, 05:49 PM
Rep:1969
Update:
Since I lifted the truck I had a large gap in the new springs because of the increased length. I thought about making my own spacers but did a quick google search and found the Airlift Lock N Lift spacers. I emailed Airlift and they told me they weren't intended to work for this application (they were very unhelpful) but I figured I could make them work. Ordered these spacers from Andrew (at Bully's Performance) a couple weeks ago and got them installed over the weekend. Had to do a little bit of modding to make them work the way I intended them too (cut the lock tabs off the top and bottom spacer) and then I had to drill out the center hole for the bag to go up into properly. Other than that they work great, exactly as I wanted them too.
I got the kit for a 6" lift (even though RCX only lifts the back 4.5") but I did end up using all 6" of the spacers. It just fit better IMO and will keep everything nice and tight.
The one issue I ran into was my airline length... when I first installed the kit I wasn't intending to put them through a 6" spacer before the bag so it was a little challenging getting them hooked up with very little play room.
6" Lift N Lock Spacers
Old 08-21-2013, 05:50 PM
Rep:1969
Here's a picture towing my dad's car a couple weeks ago. I hadn't bought a big enough drop hitch yet and I wasn't running any air in the bags so it was squatting quite a bit and the trailer was fairly tilted. But it worked fine for the 10 minute drive home from the track.
airlift, bags, towing, truck
