Old 05-23-2013, 07:03 PM
Kaner1000 Kaner1000 is offline
Vehicle: 2012 Sport
Kaner1000 is on a distinguished road
did you do the install yourself?
if so how was it?
Old 05-23-2013, 07:11 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
if so how was it?
Yes I did. I will start with saying I'm very mechanically inclined.... so for me the install was super easy. But even if you aren't, just installing the bags isn't hard at all.
I chose to take my rear springs right out to install the bags. It is possible to deflate the air out of them completely and squish them into the coil though. Just remember to connect your airline to the top first and fish it through the frame where the spring sits otherwise you won't be able to get at the connector. From there you can just run your lines along the frame and down to the hitch. You can either T the lines together so they are running the same pressure all the time or keep them separate to have the bags at different pressure if needed. If you're only going to be using them for towing I'd recommend T-ing them together. If you plan on hauling heavy loads in the bed that might be unbalanced I'd keep them separate. After that you can mount the filler valve(s) in the hole(s) on the hitch near where the chains attach.
My install was a little more complicated than that as I hooked them up to the Airlift WirelessOne compressor as well... so my lines run differently and into a manifold etc. The total install probably took me about 4 hours but the majority of that was mounting my compressor, relays, manifold, wiring, etc. Doing just the bags themselves is probably about an hour tops.
Old 05-24-2013, 12:48 PM
Vehicle: 2012 Sport
wow
thanks for the details man
with all my landscape projects I don't know if I'll have time this summer to do that myself - plus I'm only moderately mechanically inclined
Old 05-24-2013, 04:44 PM
Rep:2026
Even if you're only moderately mechanically inclined you shouldn't have a problem just installing the bags. As I said, it's fairly simple and straight forward. Plus just doing the bags should only take you an hour, 2 hours max! So I'm sure you can fit that in your schedule somewhere
Old 05-24-2013, 06:24 PM
h2oman's Avatar
h2oman h2oman is offline
Vehicle: 2012 Ram 1500
Trim Level: Express 4X4
Rep:349
Make sure you get the wheels off the ground. Otherwise its a pain. But if a retard like me can do it...
333Half the beast
I used to be
Old 05-27-2013, 10:43 AM
UpToNoGood's Avatar
UpToNoGood UpToNoGood is offline
Vehicle: 2014 Ram EcoDiesel
Trim Level: Laramie Longhorn
Rep:61
UpToNoGood will become famous soon enough
Ya those are nice. That's probably what I'll go with once I lift it. For now I just don't tow enough or long enough distances to justify the cost. What brand do you have?
Sorry for the delay. I got this one for my F250 and have since sold the Ford, but keep the hitch for my 2013 Ram. It is now over kill for this 1500, but I figure the money has already been spent and it is mine forever.
http://www.thehitchstore.com/channel...nt-p-2562.html
2014 1500 Laramie Longhorn CC 4x4 8spd, 3.92 EcoDiesel - Hammerhead rear bumper sprayed with Linex - Iron Cross steps sprayed with Linex - Trucks cover tool box/Tonneau Cover combo - Geno's cabin filter - 275-65-20 Nitto Terra Grappler - Air Lift 1000
Old 05-27-2013, 01:27 PM
Rep:2026
That looks pretty good. Different than the other adjustable drop receivers I've seen. I don't think it will have enough drop for me once I lift the truck though. The one I have now is 2 3/4" drop I believe and I already need more (probably a 3 1/2" or so). Then with the 6" lift lifting the back another 4" I would need about 7-7 1/2" drop.
Old 05-29-2013, 06:23 AM
UpToNoGood's Avatar
Rep:61
I think the one I have gives me up to 10 inches of drop. I would need to check for sure. It is however super heavy and super strong. I would not want to rear end that hitch in a car.
Old 05-29-2013, 06:31 AM
UpToNoGood's Avatar
Rep:61
Here is the exact one I got from Cabelas.
OneMount is the brand.
http://www.cabelas.com/product/OneMo...h-All+Products
Old 06-04-2013, 06:16 PM
Rammers Rammers is offline
Trim Level: slt big horn
Rammers is on a distinguished road
That is a very nice look on your truck. I bought the air lift 1000 bags and was told they would work with the rough country 2 1/2 level lift kit. Unfortunately it doesn't seem to work. I have contacted some of the dealers and the manufacturer. They say it will work but nobody can tell me how... Any ideas as the lift in the back has a solid cover instead of the top of the coil being open like it once was? Thanks
airlift, bags, towing, truck
