Old 05-13-2013, 07:54 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I know on 3rd gen hemi's the TB would not open to 100%, I assume all the newer fly by wire TB's are similar(I ASSume....).
Sean
Old 05-13-2013, 08:36 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:597
Most likely 76 degrees not percent which means the TB blade is wide open.
Originally Posted by arlockstedt View Post
Still a few questions though. I used a scan tool and noticed the throttle body only opens about 75%? Shouldn't it open all the way under full throttle? Also just hit 65k and same plugs. Will new plugs make a difference? Thanks for the input!
Old 05-14-2013, 11:46 PM
Bg Rd Ram's Avatar
Bg Rd Ram Bg Rd Ram is offline
Vehicle: 2012 Ram
Rep:19
Bg Rd Ram is on a distinguished road
i have recently looked into when the plugs need to be replaced and it is recommended at 35k, which seems low. Especially since most newer cars are at least 100k. From what I read it has to do with the type of plugs (non-platinum) because of the ignition system. I would look into that.
Old 06-17-2013, 05:41 PM
hemipowerv8 hemipowerv8 is offline
Vehicle: 2013 Ram Sport CC 4x4
Rep:74
hemipowerv8 will become famous soon enough
Ok I have an 09 crew cab hemi and the ruck had S&B intake, Diablo Tuner, and larger TB. It ran really nice. Last thing to get was the exhaust. I went with an 18in Magnaflow Tru-X dual exhaust setup. At first the sound was really nice and I think that made me feel like it was better.
One thing...if it ran well then not so much now either you got used to the additional power OR the adaptives have trimmed the timing and AFR a bit to make up for it...could pull a fuse (it's #2 on Challengers) and reset the adaptive stuff on the computer.
I have the 18" Magnaflow and a Y pipe...I am considering a swap to the dual in/dual out 14 or 18 with the internal X pipe like you have...does this model sound any different? Perform better?
Mods: Tint, Line-X spray in, PD emblems, Weathertech mats, Honeycomb grille, Mopar tow hooks, Magnaflow 18" and Y, Bilstein 5100s @ 2.1" & TGC rear spacer .75", Toyo All terrains 35x12.50x20, 5" black tips, BakFlip tonneau cover, 87mm tb
Next: Gorilla lifetime lug nuts, CAI, Diablo tune.
Old 06-21-2013, 06:48 AM
S.C. Express S.C. Express is offline
Vehicle: 2012 Ram Express
Rep:63
S.C. Express will become famous soon enough
I only know of one or two guys on here that have that setup. One guy swore he lost power, but later said it seemed to come back. This is a case of "if it ain't broke, don't fix it" Spend that money on some long tube headers if you want to get the most of your mods.LT Headers are dyno proven to add 40 hp rougly with a broader powerband and sound orgasmic. ALL the fastest trucks on here run LT headers. All high end muscle car builds use L/T headers if they can make them fit. Shorties are not worth the money or effort on our trucks. 9hp tuned roughly..
Jones MaxFlow 18" muffler swap, Green Performance drop in air filter..
Old 06-23-2013, 02:22 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
the computers are adaptive, so to take advantage of the new flow you should reset the pcm and drive it hard/aggressively for a week..pcm will learn quickly how much better the flow is and adjust the fuel tables according to take advantage of it...
5.7 e.t.'s: 1/8 - 7.85@93.20, 1/4 - 12.10@113.96 juice - 12.96 NA... 6.4 e.t. 12.59@106 NA
