Old 09-30-2013, 11:56 AM
mineralram's Avatar
mineralram mineralram is offline
Vehicle: 2013 Dodge Ram
Color: Bright Silver Mettalic
Rep:166
mineralram has a spectacular aura aboutmineralram has a spectacular aura about
Weird my Sport 1500 came with this Raised Ride height also and i inquired about it with Ram Customer service and was advised that it is nothing special and the Raised ride height was included with all trucks that came with Factory 20' rims.
Sound like they may be wrong does anybody have raised ride height with factory 17" rims
Old 01-17-2014, 05:16 AM
Silvercreek's Avatar
Silvercreek Silvercreek is offline
Vehicle: 2013 Laramie
Trim Level: Longhorn Crew Cab
Color: White/Gold
Rep:487
Silvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of light
I don't think you'll find a stock RAM 1500 with 17" wheels along with the "Raised Ride Height" option. All of the trucks I've seen with "Raised Ride Height" had 20" wheels on them.
"One Small Step For Man, One Giant Leap For RAM Fans"
4th Generation - 2013 RAM Laramie Longhorn
*** US Army Retired - 11B40 - 1964/'85 ***
Old 03-16-2014, 07:27 PM
Power Wagon's Avatar
Power Wagon Power Wagon is offline
Vehicle: 2013 Ram
Trim Level: Quad Cab 4x4
Color: Deep Cherry Red Crystal
Rep:45
Power Wagon is on a distinguished road
I believe the front struts are 0.75" higher. That's what I've read around the forum at least. The back height should be the same.
The Outdoorsman trucks also have a different front valance to give a little give approach angle (along with the raise front end).
So keep in mind that if you order a lift kit or a leveling kit, you will be 0.75" higher on the front than what the kit says. Therefore a 2.5" leveling spacer will not work for you, you'd need to go 2" to avoid problems with CV shaft angles. That problem would go away if you leveled with Bilsteins though.
I've been wondering how much that XZNP code on my truck ('13 Express Quad 4x4) equaled in numbers. 3/4" is totally believable for clearance on the 20" rim/tire combo. That set-up on that truck does give it a somewhat awesome stance for a completely factory stock vehicle.
Old 03-16-2014, 08:34 PM
macc08's Avatar
macc08 macc08 is offline
Rep:722
I read somewhere that its an additional 1" and comes stock on the sport and outdoorsman models.
Mine has it, and to all other sport owners, I'd be willing to bet that if you got a hold of your build sheet, its on there too.
an extra inch never hurts!!!!!!!!!!
Old 03-17-2014, 12:27 AM
kev12345 kev12345 is offline
Trim Level: Sport 4x4
Rep:14
kev12345 is on a distinguished road
so adding bilsteins at 2.1" will only raise it 1.35"?
Old 03-17-2014, 01:16 AM
2013 TrueBlue Ram 2013 TrueBlue Ram is offline
Vehicle: 2013 RAM 1500
Color: True Blue
Rep:45
2013 TrueBlue Ram is on a distinguished road
Default I disagree
I'll have to disagree with this statement.
I have " Raised Ride Height " on my build sheet which also has the 17" wheels listed.
Old 03-17-2014, 11:25 AM
Vehicle: 2013 Ram
Rep:45
Here's a reply from ChryCo engineering on the Raised Ride Height sales code :
It (XZNP) applies to vehicles that require a different mount during the build process when extra clearance is required due to such things as 20" wheels being selected. It is not an option that is selected when ordering the vehicle, rather it is determined to be needed by the options on the vehicle during the build process.
Old 03-17-2014, 01:07 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
On an Outdoorsman, yes.
Old 03-19-2014, 01:54 PM
Bushmaster's Avatar
Bushmaster Bushmaster is offline
Vehicle: 2014 Ram 1500
Trim Level: Outdoorsman 4x4 CC
Color: Bright White Clearcoat
Rep:83
Bushmaster will become famous soon enough
I disagree with this also, my Outdoorsman has the "Raised Ride Height" option.
Bakflip G2 tonneau cover, SunTek clear wrap complete front end, Trail FX wheel to wheel nerf bars, Huskyliner mudflaps, Weather Tech front floor mats, rear Recon mini lightbar,20% tint front door windows, 5% tint rear door/rear window, Smittybilt Lightbar with 10" Rigid LED lightbar
Old 03-19-2014, 07:36 PM
The Crow 1994 The Crow 1994 is offline
Vehicle: 2013 1500 Big Horn Crew 4x4
Trim Level: Hemi 5.7L w/8 Speed
Color: Copperhead Pearlcoat
Rep:54
The Crow 1994 will become famous soon enough
I've got "XZNP Raised Ride Height" on my '13 Big Horn with 20" wheels.
Mod List: Line-X Platinum Spray-On Bedliner, BakFlip VP Tonneau Cover, TufTruck 1223-V HD Coil Springs, Bilstein 4600 Shocks, Airlift 1000 Air Bags, Airlift Wireless One Remote System with Onboard Compressor, & Weathertech Digital Fit Floor Liners
