Old 05-01-2013, 07:36 AM
ramaries ramaries is offline
Vehicle: 2013 Ram
Trim Level: Outdoorsman
Color: Blue
Rep:39
ramaries is on a distinguished road
Default XZNP Outdoorsman Raised Ride Height
I didn't realize the outdoorsman has a raised suspension higher than the other trims. What is the height compared to the other trims?
Old 05-01-2013, 12:22 PM
Vehicle: 2013 Ram
Color: Blue
Rep:39
bump
Does anyone know what the difference is (XZNP Outdoorsman Raised Ride Height) between outdoorsman and other trims?
Old 05-01-2013, 12:47 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
I believe the front struts are 0.75" higher. That's what I've read around the forum at least. The back height should be the same.
The Outdoorsman trucks also have a different front valance to give a little give approach angle (along with the raise front end).
So keep in mind that if you order a lift kit or a leveling kit, you will be 0.75" higher on the front than what the kit says. Therefore a 2.5" leveling spacer will not work for you, you'd need to go 2" to avoid problems with CV shaft angles. That problem would go away if you leveled with Bilsteins though.
Old 05-01-2013, 01:47 PM
Vehicle: 2013 Ram
Color: Blue
Rep:39
Thanks. That should mean I wouldn't have any problems goting to a 285 70 17 instead of the stock 265 70 17 although I saw where someone had posted that on another trim the 285 rubbed.
Old 05-01-2013, 01:50 PM
Rep:2026
Nope, you shouldn't have ant problems running that size. They are essentially 32.5" x 11.25" Which is shorter than the stock tires on the 20" rims and only a little bit wider. If you do have any issues with rubbing it would be on the upper control arm. If so, 1/4" wheel spacers would fix that no problem.
Old 05-01-2013, 03:24 PM
Shreve T's Avatar
Shreve T Shreve T is offline
Vehicle: 2013 black Gold
Trim Level: Larime Longhorn
Rep:27
Shreve T is on a distinguished road
I went through my build sheet on my Longhorn and it has this same code XZNP Additional ride height... Why it was oedred like that is beyound me
Old 05-01-2013, 11:49 PM
Explorer Rob's Avatar
Explorer Rob Explorer Rob is offline
Vehicle: 2013 Ram 1500 4x4
Trim Level: Laramie Longhorn
Color: Black Gold / White Gold
Rep:264
Explorer Rob is a jewel in the roughExplorer Rob is a jewel in the roughExplorer Rob is a jewel in the rough
I have the same code on my build sheet for my Longhorn with air-suspension.
Old 09-29-2013, 01:22 PM
jschild jschild is offline
Vehicle: 2014 Ram 1500 R/T
Trim Level: R/T
jschild is on a distinguished road
We have the XZNP Raised Ride Height code on a 2014 R/T build sheet so that does not compare with the four-door or 4 wheel drive trucks mentioned. What could that mean on a two door 6.4 bed truck?
Old 09-29-2013, 04:14 PM
Rep:264
I've seen a couple of different reasons cited for the raised ride height. One reason given is that Ram increased the front end to slightly level it. Another reason I've seen is to allow for the 20" tire/wheel combination. It does seem that most if not all Rams have the code listed on their build sheet.
Old 09-29-2013, 08:05 PM
mids mids is offline
Vehicle: 2013 ram 1500
Rep:73
mids will become famous soon enough
Our '13 Bighorn with 17's and air suspension, has only this line regarding ride height. It is the truck in my sig.
XZMP Standard Ride Height
Black 2013 RAM 1500 Big Horn 4x4 QC with 8spd, Hemi, air suspension, 3.92, 8.4AN, Alpine audio, anti-spin rear. 17" rims, and 3x Infinity Kappa 32.9 in dash location.
